3-Point Hitch hudraulic system
   / hudraulic system #1
rickc2002
south hill,va
Farm Pro 4/wd 2430 diesel
my three point hitch will not maintain level. need bleeding?
   / hudraulic system #2
What kind of tractor you got? You either have a leaking cylinder or a leaking valve. If your tractor has flow (speed) control for the 3 point try shutting it clear off with the 3-point raised and see if it will hold. If it does, it's your valve leaking. If it still settles, your cylinder needs new seals provided the flow control can completely stop the flow. If you don't have flow control you can't know for sure which is leaking by. If it's really consistent the way it settles, it's probably the cylinder. If sometimes it holds, and sometimes not, you probably have something stuck it the valve.
Unused 2025 CFG Industrial MH12R Mini Excavator (A59228)
Unused 2025 CFG...
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59575)
2019 WABASH...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
