Rims Hub centre question
   / Hub centre question #1
LondonDave
Bronze Member
Melbourne, Ontario Canada
John Deere 5410 MFWD, Case IH 5230 MFWD
I'm looking at a used set of rims and tires for the 93 Ford 3930. My hub centres are 5.5" and the ones I'm looking at are 6". The bolt spacing is the same. Will these work with the larger hub spacing?
Dave
   / Hub centre question #2
It depends if your wheels are hub pilot type or not. With hub pilot type the wheel is centered and supported by the center hub, the nuts / bolts usually have a flat head against the wheel and just hold the wheel on.
If your nuts / bolts have tapered head (like automotive style wheels) the tapered nut / bolt center the wheel and hold it on.
If your current wheels are the latter the ones with the 6" center will work if the bolt pattern is the same.
Ok. Makes sense. Thanks. I'll check the bolts on my current set up.
2014 PETERBILT 388 AUTO TRANSPORTER (A52576)
2014 PETERBILT 388...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2023 JOHN DEERE 8R370 LOT NUMBER 220 (A53084)
2023 JOHN DEERE...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2013 PITTS TRAILER 48X102 3-AXLE STEP DECK (A52472)
2013 PITTS TRAILER...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
