HST temp
/ HST temp #1
Rfisher7381
South West Michigan
Kubota BX2360
Finished routine mowing then checked the HST temp using a infra red thermometer. The temp was around 185 degrees. Is that high?
Info:
BX2360 (2011)
About 110 hours
Grass average height - not a hay field
Mowing time was about 1.5 hours
Air temp was around 78
Using SUDT2 in HST
Engine temp never went over half way
60" mid mount mower
Unit did not lug or appear to be working hard
Fan blade is clear and and undamaged
Operated in high range 2WD
/ HST temp #2
I think you'll find that 100 degrees above ambient temperature is about normal, so apparently you weren't much over that. So the short answer to you question "Is that high?" would be, Nope, about normal.
/ HST temp #3
Just the other day I mowed the lawn with my BX1500. My working conditions were exactly like yours, the only difference is that I have a 54 inch deck instead your 60 incher. I also use SUDT2. I checked the trany temp at several different locations with the infrared gun and the readings were between 180 and 190.
I'm glad you posted this question because I was wondering if my trans temp was normal, I guess it is.
/ HST temp #4
Incidentally, this topic comes up from time to time. In fact, I was one of those who wondered if mine was getting too hot some years ago, so you sure aren't alone. I don't know that you'd really get a lot more information, but if you wish, you could read some of these old threads.
Rear axle temp
hydro oil temp
hyd. operating temperature
And I'm sure there are others if you search for them.
/ HST temp #5
On compressors, we run a thermostat that keeps our oil between 190F and 210F to burn off condensate. Shutdown is 240F, designed for an ambient of 125F. I would say that is normal operating temp and would not be concerned at all. Philip.
/ HST temp #7
I checked Sauer-Danfoss' website. They are one of the world's largest makers of hydraulic components. They have a very detailed section on fluid for hydraulic components including which fluid for which temp and how each component (piston pump, valve, gear pump, steering control) works with different fluids. Looking at the chart for the fluid that covers UDT, 95 degrees C is the upper continuous limit although a hydro can go to 115C intermittently.
/ HST temp #8
This was last summer ; sunlight temp ( rather than 95f shade )
and trans oil temp ..................
/ HST temp #9
I have the same tractor .. dropped a temp probe down the filler hole and it maxed out at 212. Changed to Amsoil after 50 hrs and got 203 (but on a slightly colder day). Use mine to mow in 4wd low range. So I guess that's what they run at.
2020 International LT625 48" Sleeper (A62613)
2020 International...
2021 PETERBILT 388 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2021 PETERBILT 388...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
