HST steering
/ HST steering #1
BER
SW. Indiana
MF1235 HST MFWD
Can the HST steering be damaged when turning the steering wheel while the engine is not running? I have done this a time or two so to reach a grease nipple. It sure is hard to turn without the engine running!
/ HST steering #2
I really don't believe that you can damage your power steering by attempting to turn the steering wheel while the engine isn't running, and I'm sure someone will correct me if I'm wrong here.
That said I'm not sure why you would need to, as it's very easy to start the engine for a short burst to set your wheels where it's easiest to do your lube then turn the engine back off to lock the wheels in position.
/ HST steering #3
My manual for my JD4100 actually says that it is specifically possible to steer the tractor when not running during towing or when loading on a trailer, but that the force required may be higher.
- Rick
2020 John Deere 1795 Planter (A63109)
2020 John Deere...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
Takeuchi TB225 (A62177)
Takeuchi TB225...
2011 John Deere X540 Lawn Mower (A63116)
2011 John Deere...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
Vermeer BC1800A Wood Chipper (A61166)
Vermeer BC1800A...
