HST Question
/ HST Question #1
Kubotaah3130
Chpachet RI
Kubota L3130
Hello everyone. Long time browser first time user. I own a L 3130 HST. Ive owned it for just over a year and have logged about 150 hours. To date the only issue ive had with the tractor has been ......NOTHING!! /forums/images/graemlins/grin.gif
Until today. /forums/images/graemlins/mad.gif
I have my digital display telling me "HST NEUTRAL" I know that this means the HST isn't in neutral but the pedal is centered. I checked the cruise control arm and its not pushed forward. I had just pushed a brush pile into the woods for a friend (Figures it breaks in a friends yard) backed it up and went into the pile again this time I hit a stump that was covered, the tractor stalled and that was it. I'm lost /forums/images/graemlins/confused.gif
has anyone else had this happen and what was problem.
Thanks
Steve
/ HST Question #2
Welcome to TBN. /forums/images/graemlins/smile.gif
I do not have a 3130. But have seen other post about tractors not starting after running into under brush. Look up under tractor. There is probably a stick or something else jammed in to the linkage. If nothing was bent pulling it out should correct problem. One other item it check the wiring under tractor. you may have pulled the neutral switch loose.
/ HST Question #3
Right underneath the HST, there should be a link that connected to the HST. Follow this link to the rear you will find a switch, this switch is supposedly pressdown whenever the HST pedal is returned to neutral, but because you ran over some stumps and or brushes, chances are you knocked something out of its normal place.
Alex
/ HST Question
Thanks for the info.
Much appreciated. Off to see if I can't fix it.
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
1999 GMC C7500 Dump Truck (A61573)
1999 GMC C7500...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
