HST question
/ HST question #1
JPN800
UPSTATE NY
Whats the lagest engine mahindra makes with HST? All i see is a 3510HST (25 hp pto) I need to run a 6' bush hog and need at leats 30 pto hp and hst.-JP
/ HST question #2
I have the 2810HST and it runs a 5' Woods BB60 just fine. I would think the 3510HST would run a 6' cutter. It has 28 hp at the pto vs. mine with 22.5. I believe they are both the same basic size with different engines. I just cut part of my field with 3' tall grass and it doesn't bog down at all. The grass was a bit wet but, but i cut when I can. The rain started again and drove me back in. It didn't last long and I'm headed back out.
/ HST question #3
That is Mahindra largest hp in hst.
/ HST question #4
I have the 2810HST and have a 6' bush hog behind it and it does the job just fine. The dealer sold the combo to me configured this way and also I wanted to make sure the cutter covered my tracks. You won't be able to cut up next to fence lines or buildings otherwise.
/ HST question #5
I have the 4530 which is 42hp eng and 34hp pto and if i cut thick stuff with a 6' mower sometimes it gets overloaded so i would have to see a 25 or 28 hp pto tractor pull a 6' mower over thick stuff and handle it to believe it.
However if your gona cut stuff thats not to thick you probably want have a bit of trouble but if you get in in grass thats about 2' tall or taller I think you need a bigger tractor than a 25 to 28 pto hp.
I used to own a L2500 kubota 4wd w/FEL 5' brush hog 5' box blade. This tractor was around 22 hp pto and it was a great tractor but a lot of times it was just to lite in the *** to do what i wanted to do so i made sure that i did not buy to small of a tractor the next time around.I also wanted the HST but you couldnt get it in the size tractor i wanted but there aint nothing wrong with a shuttle shift and im very pleased with it.
4530 4wd w/FEL 6' HD brush hog 6'HD box blade
/ HST question #6
Indeed the 3510 HST is the highest engine/PTO HP HST in our line up.
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
Melroe 5525 Skidloader Backhoe Attachment (A65640)
Melroe 5525...
John Deere 1025R (A62177)
John Deere 1025R...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
Mayrath 62ft. Truck Auger (A65640)
Mayrath 62ft...
