HST question
/ HST question #1
firefighter jim
The fluid level in the HST fluid check window of my L3400 dropped somewhat since fall (from upper level in window to mid level in window). No fluid leaks noted anywhere. Loader and 3 point in same position when checked. Haven't removed and reinstalled hydraulic couplings at all. Would cold temperatures effect level? Thanks, Jim
/ HST question #3
Hi check the vent on the system . I got a b7510 hst the first time i check the oil there is nothing on the deep stick because there is a bit of pressure in the tube . So i check it twice and its ok
/ HST question #4
Hi,
Cold may matter a little, but not on a practical basis. There is always the possibility that you have somehow liberated some trapped air in the system, which is now replaced with oil. Air expands and contracts much more than oil, so this could account for the difference. I would not worry about it, so long as it is in the window correctly.
/ HST question #5
On some of our equipment it is quite noticable of a difference in fluids. This is not so much so with a compact but with the rear differntial it might be close!
On some of our larger engines like the 505cu.in it might read up to a gallon low between hot and cold checks.
2025 Auger with Bits Mini Skid Steer Attachment (A66734)
2025 Auger with...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
Hensley 16in. Bucket with Teeth Excavator Attachment (A68183)
Hensley 16in...
PORTA POTTY (A68842)
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
1999 INTERNATIONAL 4700 4X2 FLATBED DOVETAIL TRUCK (A65057)
1999 INTERNATIONAL...
