HST Problem/Advice
   / HST Problem/Advice #31
Mine's funny. Sometimes I can stall the engine but sometimes I hit relief without spinning. Mostly I run in mid range though.
   / HST Problem/Advice #32
Stalling the engine in midrange makes sense. Stalling the
engine if not at 2000 or more RPM makes sense, too. Stalling
the engine in low range, over 2000 RPM should never happen,
regardless of traction conditions.
Checking the service manual, I see the 2 hi-press access
ports for testing (fwd and rev). The specs need some
explanation. I see the high press relief for the CK25/30 is
set at 3920psi and this is called the "max working press".
That test seems straight forward.
Then there is the "continuous max press" spec of 2940 psi.
What is that and how is it tested (if at all)?
NEW Fork Extensions (A59000)
NEW Fork...
2013 Peterbilt 367 QMC 7060S 35 Ton Tri Axle Crane Truck (A55973)
2013 Peterbilt 367...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
2003 Big Tex 10PI...
