HST popping out of mid-range into neutral on downhill
   / HST popping out of mid-range into neutral on downhill #21
There isn't some dirt or junk stuck in the linkage somewhere that's preventing the lever from fully engaging low gear?
   / HST popping out of mid-range into neutral on downhill #22
I've had this happen a couple of times on my brand new tractor. I'm pretty sure the shift lever was not engaged 100%. What I found was that if it feels hard to shift into low, I need to go to a higher gear, move the tractor slightly and then shift back into low and the lever will goes all the way down. It never pops out when it slips into low easily.
Probably not the same issue but it sound similar in that is seems to be lever related.
   / HST popping out of mid-range into neutral on downhill #23
If this was a problem with an automobile there would be mass recalls, headlines, and Congressional hearings.
The longer the nanny state stays away from my life the happier I'll be.
   / HST popping out of mid-range into neutral on downhill #24
I've had it happen twice. Both times I was cutting next to the woods, so kept turning to check the position of the cutter relative to the trees. My bulky backside brushed the selection lever as I twisted, popping it into neutral.
I suspect the lever is easier to move when going downhill, and I wouldn't have moved it on level ground, but both times for me were operator induced.
   / HST popping out of mid-range into neutral on downhill #25
Sometimes I have to alternate slightly pushing the forward and backward pedals while changing ranges to make it go fully into that gear.
Likewise here.
   / HST popping out of mid-range into neutral on downhill #27
It has happen to me. I ended up moving the wrenches I had stored by the lever and my problem went away. I'm assuming I wasn't getting it fully into gear, just enough for it to work for a few minutes and then out she came. A little bit of a pucker factor.
Moved the wrenches stored there and no problem since.
   / HST popping out of mid-range into neutral on downhill #28
that reminds me on my old b7800 putting the shifter in low gear would bunch up the end of the seat belt. I really had to conciously flip the end of the seat belt back over the lever once in L range. I guess if it had been around my waist it wouldn't have been a problem.
6ft S/A Trailer (A55853)
6ft S/A Trailer...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A52707)
2016 CATERPILLAR...
(INOP) 2024 ATLAS CORPO PACF44 DEWATERING PUMP (A52707)
(INOP) 2024 ATLAS...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
