HST pedal operation
/ HST pedal operation #1
Boyde
Southern, NH
2003 Kubota L3130 TLB
I have a Kubota L3130 TLB with 3 speed HST transmission. When operating a long distance (1/4 mi) on a smooth dirt road, carrying a load in the FEL, should I use LOW range and keep the HST pedal all the way to the floor or should I use MED range and press the HST pedal down about 1/2 way. What is better for the HST transmission?
Thanks,
/ HST pedal operation #2
I had a L3130 HST,no back-hoe.It may be a little under-powered with a hoe but on the road MED range should be o.k.,Low would be painfully slow(unless you have a "fragile" load in the bucket.As long as you are not lugging the motor you should be o.k.
/ HST pedal operation #3
As nybirdman wrote,high range good for easy traveling not loaded...slow motion tractor ride.
/ HST pedal operation #4
I don't think either way matters, as far as being "better for the HST"
.. i listen to my engine, rather than worry about the HST, if for any reason it is bogging down, drop it down a gear range.
If your engine has the power to run in mid range, and you are comfortable with the speed. Run it in Mid range.
.. as a note with my hydro, when I was hauling full loads of wet heavy sand, I kept it in low range, as when I had it in mid range, I kept going faster than what I knew I should be going on the winding, hilly terrain I was operating on.
I did not know if I was hurting the HST by keeping the pedal all the way to the floor in LOW range. But by the responses I guess it will not hurt anything.
Thanks
/ HST pedal operation #6
I forget where I read this but supposedly its better to floor the HST in a lower range than to have to barely tickle it in a higher range. Something about shearing the oil less. I'd need to read more hydrostatic transmission theory to know for sure.
Both of my tractors have complained if the range is too high. Either by making more whining noise from the HST (Kubota) or the HST pedal being stiff (Branson).
/ HST pedal operation #7
Based on what I read, more hst pedal is better, as it runs more oil through the system, keeping things cooler. Very low oil flow (barely pressing the pedal, in too high gear) causes excessive heat in the oil.
2003 Keystone Cougar Model 286 Camper / 5th Wheel (A66285)
2003 Keystone...
New/Unused 3 Point Receiver Hitch Attachment with Gooseneck Ball (A65583)
New/Unused 3 Point...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
