HST over Geared tractor
/ HST over Geared tractor #41
Soundguy, I've driven both gear and HST tractors... hope you have as well.
Safety for me comes from the following:
extreme slowness of operation without risk of foot slipping off clutch
significantly reduced exhaustion factor when operating all day
if something happens, just get off the hydro pedal and vehicle stops
moving.. much faster and more smoothly, IMHO, than reaching for clutch and brake.
When at risk of tipping, HST can creep far slower than a gear tractor, thus you can "feel" your way into and past the danger point, or stop before getting TOO far into it so you can take remedial action (drop FEL, change angle of front wheels, etc.)
When operating with a partner in front or rear, extreme slow operation allows partner to get out of way and stay there when hooking up implements, chains, etc.
Agreed, either tractor can be operated in an unsafe manner if you really try.
HST gives a wider range of safe operation and recovery options, IMHO.
As regards reliability, this topic has been addressed before on TBN... and my recollection is that HST was viewed as extremely reliable, even more so than gear/clutch.
In the long run, however, HST or Gear seems to be a mostly religious/emotional argument with proponents on both sides...... some of whom are extremists!
[[ I wouldn't have made a comparison post if I hadn't.. that would be kinda uh.. pointless... I've also driven just about every make of heavy equipment fromt he 50's up till present including rollers, dozers, loaders, rubber tire hoes, track hoes, gradeall units, scraper pans, and motor graders. Though I don't currently have a cdl, I've also driven some heavy trucks including dumps on jobsites.. etc.
Clutch is not designed to be a speed control device. it's to engage or disengage the drive train and or pto. Using a clutch as a speed control device will lead to premature clutch wear, and getting real familiar with splitting a tractor to replace the clutch.
completely subjective statement based on task being performed. For instance.. when i mow with my gear tractor, I use the clutch once when starting off int he apsture, and generally don't touch it again till I leav ethe pasture hours later.. not sure how that gets any easier... ( again.. subjective statement based on a specific job.. it's already been covere dthat different trannies will have + or - depending on specific tasks...
kinda like dumping the throttle and or killing the ignition.. pretty much just got inertia to deal with... at average tractor speeds which are in the 1-10mph range... that shouldn't be too hard a chore.
If I'm doing something that I think a millisecond of difference matters.. or a couple pounds here or there is the difference in a tip or not.. I simply avoid doing that task that way... there's nothing I've ever done on a tractor.. EVER that's worth my life.. and if I have to be that close on the edge of oblivion then.. heck.. I just don't need to do that task that way...
sounds like you are letting someone hook up an implement while on a running tractor, perhaps in a range gear but foot ont he brake/ sounds like bad news to me.. same as having a person in clsoe proximity to a moving machine.. besides.. your argument predisposes that a gear machine can not have a creeper gear. I've seen plenty of machines with creeper gears that move in the (low ) feet per minute range.
wider range??? how.. the tractors have the same basic controls.. the workings of those controls are different, but the end result is exactly the same.. an op in either machine can manipulate the hyds, and make the tractor move forward or back, steer, operate the pto, etc... As with any equation involving a non senient tool and a human, the human is the one making the situation safe or not... not the tool ]]
soundguy
These are extraneous arguments to the obvious. Truisms, some specious, inaccurately applied...:(
larry
/ HST over Geared tractor #42
larry
A new tractor buyer would do well to test both types before making a purchase decision understanding that both gear and hydro transmissions seem to be very reliable. This would be much easier than trying to make sense of this thread. Nothing constructive being added by either side and way too much BS.
/ HST over Geared tractor #43
It's a bit obvious you don't have much experience wth geared tractors.
The throttle controls the speed...and believe me, a tractor in low gear and low rpm crawls!
And, as far as reliability...assuming one knows what they're doing, a gear transmission will last a long long time.
You're just trying to justify the extra money you spent on the hydro, I think. And, I suggest you're last comment shows you're taking this thread too seriously...and maybe you aren't the only one. I'd suggest we're all forgeting these are nothing more then machines.
/ HST over Geared tractor #44
This argument more and more sounds like " right wing branch of Republicans vs left wing branch of Democrats" and there is never a winner. As so elaborately stated here on many occasions both HST and gear tranny are just fine for given situation and application. I love my gear tractor and feel perfectly safe with it but sure would like to have an HST tractor with good FEL as well. I would never let go off my gear tractor when I buy an HST:)
JC
/ HST over Geared tractor #45
Having grown up on a farm in the 50s and spent many hours on tractors of various brands gives me some perspective on such issues. In the 70s I owned several small tractors mostly for fun, IH Cub, A and an Allis C and a larger Massey 55 with a 4 bottom plow. Four years ago I could "justify" a compact tractor and now have a 32.5 HP tractor with Hydro Transmission.
My initial thoughts were to purchase a standard transmission due to cost and knowing that it should be the most reliable and last a life time. Well my nephew who was the service manager at the dealership where I purchased it soon talked me into the hydro. The gist of the conversation was. "Hey! We sell $400,000.00 combines which only come with hydros and your brother's 12 year old combine has never caused a moments trouble as far as the transmission is concerned. Now because I have a pretty good idea of how you are going to use this machine I really think you should have the hydro."
I took his advice and have been more than pleased with the decision ever since. First off with a hydro plowing snow or grading a gravel drive way is a real treat as you can maintain a high rpm and power ratio to various ground speeds from creeping around obstructions to flying at top speeds with only the amount you depress the pedal.. And even more important the infinitely various ground speed while maintaining proper PTO speed really comes in to play with equipment such as a tiller, sickle bar mower and other such equipment. This became so apparent to me when I loaded my tiller on the trailer and took it down for my BIL to use. His equally high quality gear tractor was not capable of doing a good job of tilling as the lowest gear was still too high of a ground speed. Make sure the tractor comes with a good cruise control on it then you can then set it for .1 MPH on up to anything the tractor is capable of in increments of .1 MPH.
Many times I yearn for the good old days, but not when I think about the tractors and equipment that I used then in comparison to what is available today. Still like to drive an old Cub but mostly just for the fun of it.
Tim
/ HST over Geared tractor #46
Roy,
Why not run an ehydro for a few years and get back to us.
/ HST over Geared tractor #47
The 3 Greatest Inventions of the last 50 years.
1. The TV remote
2. The HST transmission
3. A tie between: The GPS navigational system and
the battery-operated personal vibrator
/ HST over Geared tractor #48
1. The TV remote
Battery-operated personal vibrator?:D.
/ HST over Geared tractor #50
I disagree. I have owned the tractors from 50 and 60 years ago and still have one from 35 years ago. The new ones are easier to operate, and safer to use. Experience is an important component of safe tractor operation, it is not the only component though.
I remember the good old days, used to kill people,
That's an awfull vauge statement there.
A new tractor is safer and easier to operate than an old one?
Hmm..
Yep.. uh.. no not really.. can't drawn -any- usefull conclusions from that statement.
Lets compair my 75 ford 5000 ( same as a 65 by the way for the purpose of this argument ).. and my 2000 NH 7610s.
same op platform.. same twin stick crash box.. same hand throttle in the same place.. same on off switch ( same key fits either! ) same op controls and same info from the dash.
7610s does have flasers mounted differently.. but 5000 DOES have them.
rops are available for the 5000, so you can nix that difference.
takes the same amount of work to stomp either clutch and push a couple sticks into gear...
easier and safer huh... hmmm...
soundguy
/ HST over Geared tractor #51
Speaking of the good old days I will have to say that the modern wet brakes that I have seen are hands down better than every older tractor I used (IH 424, Ford 8n, MF 35D, MF165D, MF135D and others).
Hears the ironic part with the HST I rarely use the brake for anything other than a parking brake.
I liked all of the old iron and still would like to have a few to tinker with. I have to say for the type of work that I do in the environment I do it in the HST is safer and faster than any I have used. I always felt threatened when I would clutch in the trans to shift from forward to reverse and am on a hill the brakes mashed real hard to hold me in a safe place. I am thinking at this point if 1 thing goes wrong I am going for a bad ride with an even worse landing. This one thing sold me on HST, when you go from forward to reverse the tractor doesn't go through a freewheeling moment. It may not be something that matters to others but I now go to those same places transition from forward to reverse and not even use the brake. Remember everybody operates different and what work well for me may not for you.
/ HST over Geared tractor #52
Hmm..
soundguy
Well you have to have enough intelligence to select the right tractor today.
If you look hard enough you can find a tractor without improvements which could be very much like your selections.
I am quite happy with improved tractors but your welcome to buy what you want.
/ HST over Geared tractor #53
Roy,
I used to operate a buddy's 855 hydro. That's one reason I have a tractor now (not because of the hydro tranny though).
As far as buying an eHydro...nope. Just paid the 790 off last year and I'm not looking to replace a good tractor. I will admit I looked at a 3320 with power-reverser though. Had a backhoe too. Price was just under $20K, but I didn't make up my mind quick enough.
As far as the eHydro... I've little doubt I'll be able to get gear tranny components over the next 10-20 years. Odds are, the only thing I'll need eventually is a clutch. I'm not so sure about the electronic components for the eHydro.
Anyway, I am a very experienced manual tranny operator, I'm not in that big a hurry where the fractions of seconds a hydro may save could justify the costs and I'm the only operator of this tractor.
So, why waste the money?
Most of you guys use your tractor as big lawn mowers, so hydros work for you. The limited loader work or small farm ground engaging work wouldn't really justify any type of transmission choice for most TBNers. That pretty much applies to me too, as far as tasks. However, I prefer manual transmissions...simple as that.
Bottomline is, a hydro fan isn't going to change my mind and I really don't care what other folks spend their money on. But when hydro fans write stuff like "hydros are safer and more efficient"...well, they really don't have anything more to justify that then their opinion (just as I'm doing in this post). I'm pretty sure most haven't operated gear machines (or probably not a manual tranny in a car either), so they really don't have much to compare to.
The only time I'd recommend a hydro over a gear machine is for rentals. People renting equipment may have no experience with the equipment they're renting or care if they tear the equipment up. Some probably wouldn't know what a clutch is, let alone knowing not to ride a clutch.
BTW, I've been on TBN for about 10 years now. This discussion (in a multitude of threads) has been going on for as long as I've been on TBN and will probably continue long after I'm gone...
Hi, folks,
Its awesome I am getting a lot of response and I think I am starting to compare the HST and the geared version of trannies... Basically I am mechanical designer and I am trying to design my own transmission in near future for my farm tractor. Since I am working in hydraulic equipments field, I can't just give up my hydro and jump to mechanical. I think there is always pro and cons.
Thanks a lot to everyone who responsed to this thread.
/ HST over Geared tractor #55
I use my geared Case and 10' rotary cutter on my levies and it is when backing down to the water's edge or other drop off that I would love to have an HST as I have to lock the brakes and clutch it to change directions. This is not a matter of experience as I have been driving tractors for over fifty years. On flat ground the clutch isn't a problem, but if I ever get a new tractor, it will be HST. My brother won't get near an HST and at the age of 58 bought his first truck with an automatic; different strokes.
/ HST over Geared tractor #56
You understand what I am saying and that nerve racking feeling of how bad it could get if your foot slips at or you miss the gear or you start sliding (and yes a HST can slide and IF you change ranges on and HST you can miss that gear). I like standard transmission machines but for me and how I operate safety is the deciding factor.
/ HST over Geared tractor #57
These days a fella has to define what type of geared transmission he's taking about cause in the agricultural section new tractors going out with the basic collar shift may have given way to the electronic controlled multi geared tractor that is shifted by a computer according to conditions as defined by the operator. These transmissions may be a tad more complicated than the collar shift too!:D:D
/ HST over Geared tractor #58
In many (most) of the utility tractors, CUTs and certainly Sub Cuts, a gear isn't even offered. Which is a same, really. A gear might lower the price and give folks the option. Perhaps gearing up (pun intended) for this proves too costly for the manufacturers. That seems logical.
I have driven nothing but 4 and 5 speed pickups the last 40 years. Until it was retired, our first MF tractor, used over 40 years, was a gear, of course (see avatar).
The Kubota BX was purchased recently and had no option. Simple as that. My only comment is I can drive them all. My wife's car is an automatic, which is fine. My only input is this. What I would not do is compare an HST to an automatic transmission in a car. They do not operate the same and the comparison is incorrect.
Beyond that, this conversation might be helpful for someone considering a tractor that offers a choice, but little else. This deal is way, way overblown. See you around TBN.
/ HST over Geared tractor #59
I know that "feeling" all too well and for me, I feel safer with an HST. My father in law died of a heart attack while driving this tractor and we just can't stand the thought of selling or trading it, so I will keep using it and dealing with the high "pucker factor".
/ HST over Geared tractor #60
My comparisons to an automatic are in relation to the absence/necessity of using/not using a clutch, not the internal mechanism.
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
KBH Tank Trailer (A63118)
KBH Tank Trailer...
2017 HINO 268 4X2 S/A SERVICE TRUCK (A59910)
2017 HINO 268 4X2...
40' CONTAINER (A62131)
2024 Keystone RV Retreat Camper, VIN # 4YDTHRT28RW260127 (A61165)
2024 Keystone RV...
UNUSED RAYTREE RTSG30 - 30" STUMP GRINDER (A62131)
UNUSED RAYTREE...
