HST help
/ HST help #31
I know for a fact the Deere 3032E and 3038E have cruise control as an option...they even have a big blue arrow pointing to the switch on the product page :) On the 3R series cruise control is standard. Going up in size the 4M series has cruise as an option, and the 4R has cruise standard.
This sort of stuff is why I really don't put much faith in what tractor sales people say....they frequently don't know much about the machines they sell.
You beat me to it GManBart.
https://www.deere.com/en_US/product...y_tractor/3032e_compact_utility_tractor.page?
"The 3E Series Tractors can be outfitted with an optional cruise control switch that is installed on the right hand control consol. This gives operators the ability to keep a constant speed when in transportation, field mowing, or other applications where extended use of the transmission is needed. This kit is very quick and easy to install for those who desire this feature."
/ HST help #32
Would you like to inch or better yet 1/2 inch up to your tailgate on your truck to load or unload something? try that with gear! HST all the way!
We had two John deere 1972 140s lawn tractors hst when I was growing up. I tried to tear it up by going full forward then slam it in reverse so I would not have to cut grass(this was on pavement!) never had a problem with them!
I hate to be a shameless promoter of my own video, but if you want to see how slow a hydro Kioti can go:
/ HST help #33
Great example. A picture is worth 1000 words.
/ HST help #34
...and at 30 frames per second, that 80 seconds is worth 2.4M words.
Better than any explanation anyone could give. I love how he showed the travel speed isn't as dependent upon engine RPMs as is the case with a geared unit. If you need to crawl with a gear, you have to be throttled down. HST can throttle up and lay massive amounts of torque at those types of speeds. Perfect example of the "infinite" ratios provided by the HST.
:thumbsup:
/ HST help
Thanks again for the great example and video. HST appears to be way above and beyond geared. I cant wait until I figure out what I'm going to get. At least know I know that HST is a must. It seems that HST is much superior to shuttle as I picture shuttle just like a geared transmission with just a seamless lever move to reverse. I'm sure there are threads comparing shuttle vs hst as I am not the first in this boat. I need to go do some test drives.
/ HST help #36
That extreme slow speed contributes to the safety and precision of the tractor...priceless IMHO. Note that the tractor STOPS when you take foot off of hydro pedal...I once used that feature when I got dizzy and just wanted to stop until everything got straightened out again.
/ HST help #37
It's not accurate to say that HST is superior to Gear. It all depends on the application, the tasks you need to perform. There are times where Gear outshines HST. Having owned both, and even though I prefer HST for myself (because I mostly do commercial landscaping and lots of loader work)... I will say that, without a doubt, a Gear will put the HP to the ground much more efficiently, with more raw power. So, in ground engagement applications, plowing, discing, cultivating, etc...the Gear is actually better.
/ HST help #38
We all say this, but I'm not sure it's an entirely accurate way to describe what's going on for people that don't understand it. When we say putting power to the ground, some people get confused and think there's a difference in where the tires meet the ground, and that isn't the case (I know you know this). HST uses more engine power to function, so we get less power at the driveshaft for a given amount of engine power. What happens between the driveshaft and the ground is the same...probably just semantics :)
/ HST help
so when comparing a 45hp HST to a 45hp gear on a dyno at the rear wheel as an example, the gear would have more hp at the rear wheel... is this accurate based on what I have read?
the gear has somewhat of a mechanical advantage over the HST..?
/ HST help #40
Yep that is correct
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
2017 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A59906)
2017 KENWORTH T680...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59908)
2017 FREIGHTLINER...
(INOP) MASSEY FERGUSON 543 TRACTOR (A59823)
(INOP) MASSEY...
STORAGE FEES (A59908)
