HST filter stuck good
   / HST filter stuck good #41
Drill a hole through it. Tap a bar (mechanic's pry bar, in my case) in there and yarn it off. Doesn't work? Get a longer bar. Remember that business about Archimedes moving the world? It's unlovely and environmentally sketchy (wall to wall oil), but I know it works.
   / HST filter stuck good #42
Carefully run a razor blade or knife around the filter mating surface.. where the rubber gasket meets the metal. Loosened my factory gorilla-installed filters enough to loosen with a strap wrench.
   / HST filter stuck good #43
My go to tool for tough filters are as mentioned before my really big channel lock pliers,
unfortunatly many times there isn't room to use them.
My one tool that usually fits and works is a chain wrench, I have modified mine by adding a second section of chain to it so it would fit larger filters.
https://duckduckgo.com/?t=ffnt&q=chain+wrench&iax=images&ia=images
I have not meet many filters that it wouldn't remove.
2014 MACK CHU  PINNACLE DAY CAB (A55745)
2014 MACK CHU...
2026 Quality steel dump truck (A56859)
2026 Quality steel...
2023 Kubota U55-5R1 Mini Excavator (A55315)
2023 Kubota...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
