HST filter stuck good
   / HST filter stuck good #1
slan
Nova Scotia, Canada
Kubota L3240 HST
Well, I guess I put my HST filter on a bit too tight on my last change because it is stuck on there real good.
I have a metal band type filter wrench and I could not budge it no way in either direction. I even put a small piece of pipe on the handle and it started to bend the handle. This is not a cheap filter wrench either.:mur:
I have a band type that I can use with a 1/2 drive but am a little scared to be putting that much torque on the filter housing.:confused3:
Any tricks or tips?
My next step will be to get one of the filter wrenches with the jaws that lock into the notches on the filter base I guess.
Or take a shot at it?:shocked:
   / HST filter stuck good #2
Poke a good size screw driver straight through it and spin it off
abit messy but but it usually gets the stubborn one's off.
tom
   / HST filter stuck good #3
yeah, this is where those cup filters tools, that fit on your 3/8 drive are nice. Problem is having a drawer full of those cups, and dang it, you still run into filters, supposedly the exact same number and everything as before, but the makers change the diameter just a whisker different and the cup either slips or won't fit. I also like the three fingered jaw type as well. The guys at the auto dealerships swear by them.
   / HST filter stuck good #4
Do you have enough room for pipe wrench.
   / HST filter stuck good #5
   / HST filter stuck good #6
If you end up using Channel Locks or pipe wrench, try to grip the filter down low, at the base. Gripping it high up is basically twisting on a very thin tin can and it distorts easily. Let us know how it comes out. Best hopes for ya.
   / HST filter stuck good #7
Try one of those chain-type pipe wrenches. They can really apply the torque.
chain pipe wrench
I used one on the L48's transmission filter which is metal-to-metal mounted (not like the rubber O-rings on the HST filters). What finally had to be done was a come-along was hitched to the handle and the other end on the axle. That filter finally came loose. It was ugly but it was off. Good luck to you.
   / HST filter stuck good #8
next time make sure you lube the rubber first hand tight than a 1/4 turn after that.
   / HST filter stuck good #9
I second tommu56 solution. It is one I have used many times. Why go out and spend a lot of money on a new, improved filter wrench and waste all that time driving there? You already have a filter wrench. It just won't do this specific filter.
Now, get that large screwdrive and hammer!
2015 Chevrolet Duramax (A50120)
2015 Chevrolet...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
Frontier SB1107 3pt Sickle Bar Mower (A50774)
Frontier SB1107...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2019 John Deere 1023E (A50120)
2019 John Deere...
