hst experience
   / hst experience
Ok Don here's what I did. I lifted the front of the tractor using the loader and then curl the bucket down and it's at that time the HST pop up occurred ...cag
   / hst experience #32
Tilting the bucket down and pushing the joy stick to the far forward position will put the bucket into "float", which releases all downward pressure from the bucket. Might this be what you experienced?
Don
   / hst experience
Loader down then curling the bucket in the same way you do when you dump.. This of course lifted the front even higher at that time I felt the release that I suspect was hst pop up. Maybe I'm wrong here Don I never experience hst pop up before ...cag
   / hst experience #34
Sounds like you engaged the float position. Float is used to skim the bucket across the ground without digging in.
When tilting the bucket forward with the joystick you will feel a detent or stop. Continuing to push the joystick forward past the detent will activate the float position, releasing all downward pressure. I believe you activated the float position and thought it was the hydraulic relief valve popping off.
Don
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
CASE TR340 SKID STEER (A52709)
CASE TR340 SKID...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
Hose Reel (A55787)
Hose Reel (A55787)
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
