HST engine load
/ HST engine load #1
PioneerMan
If I am in high range and I mash done the pedal at slower speeds the engine lugs several hundred rpm and then catches back up. I doubt this causes damage but is it not advisable for any reason?
Tractor is 4320 cut, so 3 speed.
/ HST engine load
I meant mash down...stupid auto correct.
/ HST engine load #3
I assume you have eHydro transmission. If so, and if you have load match turned on I doubt if you can hurt anything. If load match is turned off, the tractor isn't going to like it -- hard on entire drive train and engine. Bending a connecting rod may be in the realm of possibilities.
The older 4320 tractors had a switch on the dash to turn load match on or off. The newer 4320's do not have the switch but you can program it on or off by following procedure in the Op Manual. The default setting for newer models is load match on.
BTW, why would you mash the pedal? :confused:
/ HST engine load
Are you serious? The acceleration is lots of fun but I've only done it about half a dozen times cause I am not sure what all is going on. If say I'm at 2400, 5mph and hit it the rpms go down to maybe 1800 or so, to the top speed of 12 or whatever engine speed dictate. Doesn't sound like it's lugging, just the hydraulic pump putting major load on the engine I figure. My tractor is not that old and load match is usually on, a switch on the dash. I sure get there quick! )
/ HST engine load
I just read the manual and it stated to slowly depress pedal. Probably not hurting anything but maybe not good practice either...
/ HST engine load #6
Flooring the pedal quickly is about the same as going from a low gear to a high gear in a standard transmission, that will load down any engine. You can do it but I don't recommend it, better to allow the engine and hydro tranny to build up speed gradually. No sense in straining the tractor unnecessarily.
/ HST engine load #7
PioneerMan
Don't tear it up. :D
Or get the warranty out and read it carefully before you have to use it. I'd think the "mash" technique would be abuse.
But sounds like you now know by reading the manual. ;)
/ HST engine load
No that's fair. Like I said I only did it a few times and then realized it must be a heck of a load to drop rpms like that. I do think the manual should explain the HST a little more, as my diesel pickup experience doesn't have a lot of carry over here.
NEW IDEA 323 - 1R CORN PICKER (A64277)
NEW IDEA 323 - 1R...
2013 FORD F-450XL SUPER DUTY DUMP TRUCK (A64277)
2013 FORD F-450XL...
2006 Ford F450 XL Super Duty Swab Rig (A62679)
2006 Ford F450 XL...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
Hay Rack Wagon (A66408)
Hay Rack Wagon...
Landhonor 11' x 19' Metal Carport (A66408)
Landhonor 11' x...
