HST and turning brakes works
   / HST and turning brakes works #1
daTeacha
Funk, Ohio
I drove a Case DX26 today and tried out the turning brake/cruise control thing with the following results:
You can use the turning brakes when cruise control is on. They work in either 4 or 2 wheel drive, but much better in 2 wheel drive. Hitting both brake pedals shuts off the cruise.
So for at least one tractor with the hydro pedal and turning brakes on the same side, it will work if you do it right. I thought you'd all want to know.
   / HST and turning brakes works #2
i have a mf 1547 it works the same way as above. i have to push the brake pretty hard to disengage...
   / HST and turning brakes works #3
I can't do it on my ford because of pedal placement. The hydro pedal is directly behind the brake pedals on the same side. I've never had to use it because the turning radius is so tight.
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2006 S&H HORSE TRAILER (A52472)
2006 S&H HORSE...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
2002 INTERNATIONAL 4400 BEVERAGE TRUCK (A52576)
2002 INTERNATIONAL...
