HST and turning brakes works
   / HST and turning brakes works #1
daTeacha
Funk, Ohio
I drove a Case DX26 today and tried out the turning brake/cruise control thing with the following results:
You can use the turning brakes when cruise control is on. They work in either 4 or 2 wheel drive, but much better in 2 wheel drive. Hitting both brake pedals shuts off the cruise.
So for at least one tractor with the hydro pedal and turning brakes on the same side, it will work if you do it right. I thought you'd all want to know.
   / HST and turning brakes works #2
i have a mf 1547 it works the same way as above. i have to push the brake pretty hard to disengage...
   / HST and turning brakes works #3
I can't do it on my ford because of pedal placement. The hydro pedal is directly behind the brake pedals on the same side. I've never had to use it because the turning radius is so tight.
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
Landoll Hauloll (A53472)
Landoll Hauloll...
2016 John Deere 7210R MFWD Tractor (A53342)
2016 John Deere...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
(APPROX 24) 2" X 3" X 49" THICK TUBING (A51247)
(APPROX 24) 2" X...
