HPX driveline problems
/ HPX driveline problems
Couldn't find the powder blast they were out, tomorrow I'll take er apart and just blow it out with air and see what happens.
/ HPX driveline problems #24
get some brake cleaner it works the same but i would do it while you have the cover off.powder blast is better but brake cleaner is just about the same .did you get the remington oil with teflon ?
No, but I did see it. I figured I'd just get both at the same time.
/ HPX driveline problems #26
Tried to post this once, hope it dont repeat ~~~
Be careful with the brake cleaning spray. For it will swell gaskets & rubbers seats ~~~~ Kinda caught the end of the conversation, but we used to use this on high pressure tankers / tanks that the gaskets leaked, it swelled 'em up just enough to stop the leaks. Hope I'm not a pokin' in, for I don't know what you are going to use it for, but please don't use it like carb cleaner for Gods sake ~~~~~~~~~~
/ HPX driveline problems #27
na !jump on in .i don't think there are any gaskets on the clutch. atleast i did't see any.they have some white plastic shims and they were clogged with belt dust .it's real hard to push in the clutch or should i say squeaze them together but before i cleaned mine i couldn't but after i could move them a little.mabye try some "breakfree" it's in the gun section too it a good cleaner too. leave the brake cleaner alone then. i was thinkin there is a seal behind the clutch it would be hard to get anything on it but better safe than sorry. so first choice i would use "powder blast" if they don't have that then try "break free" and then srap it with the remington oil with the teflon make sure you get all of them in the spray cans.that little tubes works like a pressure washer. hey maybe some good old carberator cleaner but i never tried that but it might work just as good.
/ HPX driveline problems #28
TOMMYHPX4X4
I didn't have any idea what you were a cleaning, but I just thought I'd throw that at ya ....
I made mistakes in my life, and most of the time, it gets in the pocket really good. Just trying to save someone some trouble, that's all ...
Being your from the great state of Louisiana, might want to look in this,
I use these folks oil, grease, cleaners, lubricates, OILS, & have been for years,talking about some quality stuff. This is the sh/t ~~ Not only does it work great for all my farming, equipment, & machine installations, IT FROM LOUISIANA MY FRIEND !!!!!
Another great product that they have & I believe in ~~~~
C-139 De Aqua Lube (Aerosol)
Penetrating Lubricant
I use this on my guns, it some kinda great for 'em !!!!
GIVE 'EM A CALL & FIND OUT WHERE YOU CAN PICK UP SOME TO TRY !!!!:) You won't be sorry, trust me !!!!
Baton Rouge Industries · Custom Engineered Lubricants · (800) 232-0334
/ HPX driveline problems #29
got it saved in favorites and i'm gonna read up on it but hey i'm all for bringing some coonass some work!! and hey don't worry about jumping in if someone reads something and they think it might cause damage by all means jump in before it does the damage. but i think he would be safe cleaning the clutch but just to be on the safe side i would try to get the two cleaners or the carberator cleaner other than the brake cleaner first like you said.i'm gonna read up on the lube you posted i use alot of it too lol.
2024 Case IH Farmall 75A (A60462)
2024 Case IH...
Topcat ECSSSTG200 (A60463)
Topcat ECSSSTG200...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
KUBOTA U55-5 EXCAVATOR (A59823)
KUBOTA U55-5...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
