rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,735
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Tractor Tech, that is a real good observation on that detent ball ! For me, that goes right to the head of the list of possible hard shifting culprits - especially since the ball won't come out. I wonder if it is even rotating? We know it has to be able to move very freely up and down enough for the shaft to slide....I forgot to ask, what does the spring and ball look like? Is the ball shiney or is it pitted?
Darned if I can think of how to get it out of the hole... but the fact that it won't come out easily makes me real suspicious about that detent ball and the shifter shaft.
I was thinking that Hank might try filing that detent hole half full of a good grease - maybe a sticky moly grease - and then see if the hydraulic pressure from a bolt or rod would force grease around that ball.
But then I got to wondering if he did that it could force grease along the shaft and into the empty space in the case that the shaft has to slide into - which could hydro-lock the shaft completely if that space is not vented - and that is something I don't know.
I wonder how much work it is to get the rod out?
rScotty
