HP rating for John Deere 10 Backhoe
/ HP rating for John Deere 10 Backhoe #1
jones6780
Lizella, Ga.
Ford 1700 4wheel drive, Yazoo/Kees Max2 Zero Turn
Any one have a JD 10 backhoe? What HP range is needed for operation? I am looking at one on an auction site. Haven't gone to actually look at the unit yet. Photos show subframe attached, looks to be a smaller hoe but has a 24" bucket. Not separate PTO unit.
/ HP rating for John Deere 10 Backhoe #2
I would be hesitant to buy a backhoe attachment if you don't know what it will fit. Not familiar with this specific model but would guess this was made for 40 to 50 hp utility tractors.
/ HP rating for John Deere 10 Backhoe #3
Most people seem to use 40 to 50 HP tractor for this.
Thanks, but if the price is right and the hoe is small enough, then I can adapt it to my tractor. I was hoping for someone that had knowledge of this particular BH to chime in.
/ HP rating for John Deere 10 Backhoe #5
So what tractor do you want to use with it? My 110tlb has a 10' hoe which should be close to the model 10 hoe you are considering.
I have a Ford 1700 4WD, 23HP. That is why I wanted HP requirements, looking for a small hoe. I couldn't find any info online.
/ HP rating for John Deere 10 Backhoe #7
That is way too small for the #10 hoe.
TractorData.com shows the 1700 is rated for a Ford 757/758 hoe with 106/140 inches of reach from the pivot. The JD 10 looked similar in size.
/ HP rating for John Deere 10 Backhoe #9
I think tractor weight and auxiliary hydraulic flow are of more concern than tractor hp.
Really weight is probably the bigger concern as technically any hydraulic flow will run, just depends how fast you want it to move.
For comparison, my 1070 is 39 gross horsepower and weighs around 3k. It is spec'd to use the jd 8a backhoe.
Well if an 8A is rated for your tractor and if the larger numbers are for larger sizes then the JD 10 BH would be too big. My 1700 weighs in at 2500 lbs. plus weights.
/ HP rating for John Deere 10 Backhoe #11
My 110 with Laurin cab weighs about 8000 lbs and is 43 hp. This is a decent weight to work well with a 10' hoe and since you operate the hoe while parked the 31 hp of hydraulic pumps seems to work out. The 10' hoe section weighs between 1600 and 2000 lbs, I can't remember the exact figure but would think the #10 is similar.
I would suggest looking for a smaller hoe and suspect they would be more common and easier to find used.
2017 INTERNATIONAL 4300 6X2 S/A 26FT NON CDL BOX TRUCK (A67737)
2017 INTERNATIONAL...
2016 John Deere 6145M (A64911)
2016 John Deere...
2025 CATERPILLAR 285 SKID STEER (A65056)
2025 CATERPILLAR...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A66736)
2015 International...
445 (A63290)
445 (A63290)
2013 PROFAB 200BBL CRUDE TANKER (A67714)
2013 PROFAB 200BBL...
