MickeyDBC
Are there any good rules of thumb for tractor horse power per foot of disc width along the lines of 5 PTO HP per foot of shredder? Need to get a bigger disc and wondering what a 70HP 4wd tractor will pull.
That depends on how heavy the disc is and how deep you want to sink it in the ground. About 12 ft is going to be plenty. I got a 12 ft case disc and with the wheels up I can pull it with a 75ish hp tractor with no problem. It is pretty light. I got a 12 ft Krause disc and it is really heavy. With the wheels all the way up I can't pull it. It really digs in. I can pull it as long as I let the tires support some of the disc. Personally if I were in your shoes, I would not be afraid of a 10 or 12 ft pull behind disc. Make sure you have hydraulic couplings on your tractor so you can run the hydraulic cylinder on the disc.
There are so many variables that it truly is impossible to get you an accurate idea without knowing pretty much all the circumstances-conditions. Just to give you an idea, A lot of people would say that my 75hp tractor would pull a 12'-14' disk. When in reality it only pulls my 8' disk. The tractor weighs in at 10,000+lbs with no loader.
I have an old pull type off-set disk with 22" pans, I've forgotten what it weighs, 3000lbs? :confused3: It's built with 3/8" & 1/2" frame material. I have rolling hills to do. On flat ground I don't even know its back there, get on the hills and on the 2 pass it works the tractor enough that I figure that a 9 footer may be to much at times.
I can pull a single pass on basically flat ground with our 12 footer as seen in the last picture, forget a 2nd pass or any hills what so ever.
So that is only an example, like I said, to many variables to actually give you an accurate idea IMO.
Just my :2cents:
Is the Mahindra turbocharged? I had a non-turbo diesel truck that would fall on its face at pretty much anything above sea level. We are at about 400 feet and pretty flat. Thanks for the pics, looks like you stay busy.
R1s vs R4s will also make a difference with ground contact.
