HP differance between B2620 and B2920
/ HP differance between B2620 and B2920 #1
sbatzold
There is 3hp differance motor and PTO on these two tractors, is it a noticable differance when finish mowing and snow blowing? I know everyone says go bigger but its around 2500-3000 differance at the dealer I checked at.
/ HP differance between B2620 and B2920 #2
I bought the 2620 and it is fine blowing snow, digging up large stumps as well as moving soil around. I went thru the same analysis that you are going thru and I'm happy with the 26 horse model.
/ HP differance between B2620 and B2920 #3
I would'nt think the HP would be that noticeable. I ended up getting the B2320 and upgraded the FEL to a LA364 which comes on the 2620 and 2920.
/ HP differance between B2620 and B2920 #4
It is a 11% increase in hp and yes you will notice. You should be able to upgrade for around $1500 not 3000.
/ HP differance between B2620 and B2920 #5
I couldn't tell a difference between the 2320 and the 2620 so I ended up with a 2320. Wish I would have upgraded to the 364 but the 304 has done everything I've needed. The 2320 has more than enough power for finish mowing (60" at least), never blown snow.
/ HP differance between B2620 and B2920 #6
I have'nt personally come across any situations where I wished I had the additional 3-6 HP. PTO HP may be different, but I don't have any PTO driven implements at this time. I have ran out of traction a couple times though. I guess it just comes down to money really.
/ HP differance between B2620 and B2920 #7
I looked at the 2320, 2620 and 2920 and ended up with the 2920. I do think the difference is noticeable, but its really more at the PTO. If you run a PTO HP intensive implement like a wood chipper or generator then the increase in HP is very important. if you don't then realistically I don't think either tractor has enough traction to be HP limited. (I think I've managed to to bog my b2920 twice with non PTO activities, once by pushing on dry pavement with lots of weight and traction and another time pulling in the same situation. It all comes down to your use. The 2320 has a different loader and a few other small differences, so that one has more differences than just HP
/ HP differance between B2620 and B2920 #8
You can get the LA364 loader with the 2320 as well.
/ HP differance between B2620 and B2920 #9
Right i should have said it comes with a different loader standard. Hydraulics i believe are identical across all 3
/ HP differance between B2620 and B2920 #10
The 2920 engine is 8.5 CID larger. That is significant in an engine of this size, and you will definitely notice the torque difference when using PTO driven equipment.
WWIW, blowing snow sucks up HP even more so than does mowing heavy grass with a rough cut mower. The 3 HP difference will not be an issue when finish mowing with a 60" or even 72" finish mower so long as you keep the grass under control. You will definitely notice it when using a rough cut mower in heavy grass.
SDT
/ HP differance between B2620 and B2920 #11
There is a $855 difference between the 26-2920 on the Kubota's web site. If the dealer quoted you $3000 then he is skinning ya.:eek:
/ HP differance between B2620 and B2920 #12
When we got ours it was $1000+ from 2320-2620 and $1000+ from 2620-2920
Most dealers will tell you the best deal $ and value wise is the b2620 as you get the stronger la364 fl and bigger tire size from 23-2620.
We got the b2920 because of residential snow removal 24" plus at times and could use the extra HP to get the work done quicker
/ HP differance between B2620 and B2920 #13
For us recently it was only $400 more for the B2620 and the B2920 was $800 more than the B2620, and the LA364 loader was $500 more than the LA304 so decided le 26 HP would be enough with the loader. If I would have thought we would need it I would have went for the 29 HP.
If you can check with more than one dealer, pricing is different at each one from what I've seen.
/ HP differance between B2620 and B2920 #14
so what did you end up getting?
I have a B2620 and run a 60" rear mount PTO snow blower and operate at 1700 rpm (well below the rated RPM needed to get 540 rpm at the PTO) and at these lower RPM the blower handles snow drifts WAY GREATER than this little tractor can handle.
100% for sure every time I will loose traction in the really deep drifts well before the engine starts to give any signs of strain even at 1700 rpm.
So for me the issue blowing snow is not HP related it is traction related. I slow down to clear the snow due to traction not due to HP. And the blower is blowing the snow in an arc and way far enough that increasing rpm seems like un needed use of rpm's. Sure if I increase rpm's I can move snow a little (very little) quicker so my choice is slightly less tonnes/hr of snow in return for lower rpm.
Tires are not filled but chained.
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2011 Ford F-350 Crew Cab Service Truck 4x4 (A62613)
2011 Ford F-350...
2020 Bobcat S450 Compact Wheel Loader Skid Steer (A64553)
2020 Bobcat S450...
KUBOTA Z121S KOMMANDER ZERO TRUN MOWER (A65054)
KUBOTA Z121S...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
2014 Kia Sorento SUV (A64557)
2014 Kia Sorento...
