Howse Brush Hog problems
/ Howse Brush Hog problems #1
coach S
My Howse brush hog started making noises a few weeks ago. I wasn't sure if a blade was hitting something under the body of the cutter making a noise or if it was the gear box. Today the bolt sheared off in the shaft attached to the gear box and I noticed grease leaking from the gasket where the gear box bolts together. Three of the bolts were backed out. Do you think the gears or a bearing went bad in the gear box?
/ Howse Brush Hog problems #2
Sounds like you just lost a shearbolt. That's common and nothing to be alarmed about. I would tighten the bolts and check the 80W lube oil in the gearbox. Also, raise the cutter and look underneath. Make sure the stump jumper pan is tight and not wobbling on the shaft from the gearbox and also check the blade bolts for tightness. The will move up-down some, but not much. Just make sure everything is tight and replace your shearbolt with a 1/2" dia. 4" long grade 2 bolt that you can buy from the bulk bins at Tractor Supply or most any other hardware store. Make sure you use grade 2. You do not want a grade 5 or grade 8. The grade 2 will have a smooth head with no marks. The grade 5 will have 3 marks and the grade 8 will have 6 marks on the head. Us only the ones with no marks on the heads. You will probably have to rotate the shaft until the holes align and then drive out the old bolt from the center shaft with a punch. The shear bolt is there to protect your tractor and gearbox if you hit a rock. It shears off and keeps other stuff from breaking.
2016 Freightliner 108SD T/A Rolloff Truck (A64194)
2016 Freightliner...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
2022 EZ-GO ELITE...
2015 Ford F-450 4x4 Crew Cab Utility Flatbed Truck (A64556)
2015 Ford F-450...
213091 (A64276)
213091 (A64276)
10ft Fork Extensions (A64553)
10ft Fork...
