Rotary Cutter howse 500 stump jumper moves vertically
   / howse 500 stump jumper moves vertically #1
sparky257
russellville,mo
massey ferguson 135
I just bought a howse 500 and was inspecting a little closer when I got it home and if you grab the blade it will wobble up and down haven't messed with it as we got snow last night just curious if anyone had suggestions for when I look at it further in the week
   / howse 500 stump jumper moves vertically #2
Is it the blade, or the whole stump jumper? Just the blade moving is normal. The whole stump jumper is not.
Aaron Z
It's the whole stump jumper I can look on top of the stump jumper at the shaft and it does not move with th movement when I jiggle the stump jumper I'm hoping that maybe I can just tighten the castle nut but idk
   / howse 500 stump jumper moves vertically #4
According to the diagram on the Howse Implement page it has a washer, nut, and a cotter pin that holds it to the gearbox out shaft. If its moving and the shaft is not moving check the castle nut and if its tight you must have something worn in between the shaft and stump jumper. Here's a link to Howse and you can go through and find your Howse 500 diagram. The parts list and price is on the right side of the page.
https://www.google.com/url?sa=t&rct...ysv268kblEXFelxNQ&sig2=eBqewlxA8Mq63apwnRYL8Q
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2017 John Deere 8370RT Track Tractor (A53485)
2017 John Deere...
Ford 8340 (A53317)
Ford 8340 (A53317)
2021 WESTERN STAR 4700 DUMP TRUCK (A55745)
2021 WESTERN STAR...
