Rotary Cutter howse 500 stump jumper moves vertically
   / howse 500 stump jumper moves vertically #1
sparky257
russellville,mo
massey ferguson 135
I just bought a howse 500 and was inspecting a little closer when I got it home and if you grab the blade it will wobble up and down haven't messed with it as we got snow last night just curious if anyone had suggestions for when I look at it further in the week
   / howse 500 stump jumper moves vertically #2
Is it the blade, or the whole stump jumper? Just the blade moving is normal. The whole stump jumper is not.
Aaron Z
It's the whole stump jumper I can look on top of the stump jumper at the shaft and it does not move with th movement when I jiggle the stump jumper I'm hoping that maybe I can just tighten the castle nut but idk
   / howse 500 stump jumper moves vertically #4
According to the diagram on the Howse Implement page it has a washer, nut, and a cotter pin that holds it to the gearbox out shaft. If its moving and the shaft is not moving check the castle nut and if its tight you must have something worn in between the shaft and stump jumper. Here's a link to Howse and you can go through and find your Howse 500 diagram. The parts list and price is on the right side of the page.
https://www.google.com/url?sa=t&rct...ysv268kblEXFelxNQ&sig2=eBqewlxA8Mq63apwnRYL8Q
2011 Kia Forte Sedan (A55853)
2011 Kia Forte...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55851)
2022 Polaris...
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2024 Case IH Patriot 4450 Sprayer (A53485)
2024 Case IH...
