Howard Rotovator HN
   / Howard Rotovator HN #1
Barney6595
Grants Pass, Oregon
kubota B6100-D
I have an old "Howard Rotovator HN" that came with my B6100-D Kubota Tractor 35-40 yrs ago. I now need the small sprocket at the top of the drive chain. Large at bottom and chain are still usable. I can not find any part numbers on the sprocket. Is this sprocket available new or used? Been searching the internet but with no luck. I do have pictures and diagrams with measurements.
   / Howard Rotovator HN #2
A FORD 105 tiller is exactly the same as a Howard HN. Its known as a Howard Cadet J style tiller. Ford does show the part # in their system.
   / Howard Rotovator HN #3
IF you only replace one sprocket and use the tiller much, that sprocket won't last.
It should all be replaced as a set, as the sprockets and chain wear as a "set".
SR
Thank You - that's a lot of help
SR
I know that to be true, but finding the one gear would be better than nothing. But I since I just recieved a reply letting me know where to find the part , I will replace both gears and chain.
This forum has been a real time saver. thanks
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
1268 (A50490)
1268 (A50490)
2017 Volkswagen Jetta Sedan (A50324)
2017 Volkswagen...
Wanco 800W Solar Integrator Trailer (A51691)
Wanco 800W Solar...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52748)
2016 Kawasaki 70...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
