How would you fixture this?
/ How would you fixture this? #1
Jim Timber
Veteran Member
Metro/Brainerd, MN
JD 5065e MFWD w/553 FEL
14 gauge 1.25" round tube "T" with a stub leg fish-mouthed onto the long leg. The two horizontal sections need to be parallel within a couple degrees, but it's not mission critical.
Would you make a "V" base to lay the three sections into which allowed access to the joints from both sides, or would you just put it all on a flat plate with some location tabs to hold things enough to tack it and then remove from the fixture to finish?
I have 100 of these to do and would like to MIG them after TIG tacking (if needed). When I did production MIG welding, we always made better time the more of the part that could be welded in the fixture. Fixtures were often hinged to get to the back. Those were more involved assemblies though. Once these are tacked, they can be finished in a vise with ease.
How would you do it?
/ How would you fixture this? #2
With that many to build. I would make a fixture out of angle iron, with the toes up, tacked to a flat plate.
The top of the T is also fish-mouthed too. I should've clarified that.
Would you make it so the whole joint could be welded in the fixture or just to tack it and then finish it outside the jig?
My only consideration outside aesthetics and strength (not a highly stressed part) is that the top of the T needs to be smooth. I can do that with a high inductance easy enough with MIG, but I've been tigging these in the past (10 units total to date). Now that I'm making volume, I want to go with the cheaper process. As long as no one gets blisters, I don't think they could care any less how they're welded.
/ How would you fixture this? #4
I'm no fixture expert but I like V grooves. Tends to take any slop out of the fixture compared to tabs or pins on flat surface. Design so you can easily tack without having to move the part during. My :2cents:
The mouths hold the tube in orientation, so having tabs is sufficient on this one. I still agree with you on the v bedding for rounds.
I am thinking maybe a V groove bed with toggle clamps attached to a backbone would allow access to both sides of the joints.
/ How would you fixture this? #6
I like toggle clamps too. Make sure you don't have plastic tips on them... ask me how I know. :duh: Although just using for tacking, should be no issue.
I don't buy the ones with plastic tips. :laughing: I started welding one of these last night so I could build the fixture off it and accidentally set it on a scrap of UHMW that was in the debris on the floor after welding it. :eek: It came off, with a little effort. :laughing:
I'd like to fully weld these in the fixture if I can, but I'm not **** bent on that. I'm getting a clearer vision of the jig I should make. I think it'll work pretty slick.
/ How would you fixture this? #8
I would use the fixture just for tacking. Remove the T from the fixture, put a square on it. Then I would know where to make my first weld.
John Deere Gator (A53317)
John Deere Gator...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A59231)
2019 Harley...
2014 Top Hat Trailer (A60352)
2014 Top Hat...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2014 Toyota Tundra Single Cab Pickup Truck (A60352)
2014 Toyota Tundra...
