How would you do this?
   / How would you do this? #1
Secret Squirrel
Mahindra 3510
In order to reinforce certain sections of the pressure-treated wood deck on the back of my house, I needed to drill some 9" deep 1/2" diameter holes for thru-bolting. Problem is that the holes are going through numerous 2x4s and a 4x4 in each case. Those pieces of wood have nails in them, most that I can't see behind the face wood. Big nails. Lots of nails. And yes, I managed to hit nails in all but one instance. I'm only amazed that it wasn't in every instance.
Because of the great depth, I am using one of those extra-long 1/2" drill bits. But those extra-long drill bits are made to go through wood only (for home wire installations mostly) and not even pressure-treated wood. It is not a hardened drill bit. At the nails, it just stops no matter what I do. Further, I am told that a rented hammer drill won't help. And in most cases, I can't get behind the holes with my drill to attack the nails from the other side.
How would you try to drill these holes through pressure treated wood with a lot of nails in them? Is it just about finding an extra-long 1/2" hardened drill bit? Do they even make them 10" or more long? If so, where would I get one? Any ideas out there?
Rusty
   / How would you do this? #4
Wow! Looks like exactly what I need! Thank you!
they work great but are a little hard to keep going in the direction you intended, especially when you hit something. I've found a small pilot hole helps, the bit can still get a bite to cut through things but doesn't wander around as much.
   / How would you do this? #5
Use a drill with large handles. Those bits can be wrist breakers in a strong drill.
I bought that Greenlee bit and it did enable me to drill one more nail-filled hole. Then it seems to have quit. The tip of the bit looks pretty badly mangled.
I'm going to need to take a whole different approach to this project. $25 per hole is too much. Thanks for trying but those darn nails seem to have won.
Rusty
   / How would you do this? #7
Big second on this one...I broke my hand in almost the exact same situation.
After 2 months of physical therapy, I found an expensive corded drill with a clutch and used it to drill the rest of the holes:
3/8 in. Variable Speed Clutch Driver-D47CK at The Home Depot
By the end the drill was trashed, but the clutch saved me from breaking my hand again several times.
   / How would you do this? #8
   / How would you do this? #9
You might have more luck with smaller bolt, should be better chances of getting a hole through. A 1/2" bolt is good for something like 10,000 pounds depending on the grade, can't imagine anything on your porch approaches that requirement unless you're collecting grand pianos. A 3/8" is good for 5-6000 pounds, you might even go down to 5/16". Is the purpose of the bolt to compress the deck members, or are you depending on it to perform in shear?
   / How would you do this? #10
If you have an impact wrench you might try driving a lag bolt first, then drill. This could move things (nails) enough for you.
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2005 Ford Explorer 4X4 SUV (A53424)
2005 Ford Explorer...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
