how would i tighten this fitting down onto an Aeroquip fc-234? (please see attached )
   / how would i tighten this fitting down onto an Aeroquip fc-234? (please see attached ) #1
bdubose
i don稚 own one
as you can see from the photos, there is no nut with flats to be able to tighten the part that is supposed to be inserted into the part with flats that is turned CCW down onto the hyd. hose. (i have seen other, similar fittings that DO have the nut). Thank youse! 0A4C6BA6-E2C2-49CA-BA6B-C71E2CBAA009.jpegBAC3AE4A-CDF5-465D-8BB0-259D92AB7053.jpeg
   / how would i tighten this fitting down onto an Aeroquip fc-234? (please see attached ) #2
   / how would i tighten this fitting down onto an Aeroquip fc-234? (please see attached ) #3
Tighten the fitting down on a mating male fitting, then complete the splice.
Thanks!
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
RIDGID K-400 POWERED DRAIN CLEANER (A51248)
RIDGID K-400...
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2017 JOHN DEERE 8270R LOT NUMBER 175 (A53084)
2017 JOHN DEERE...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
