How would a Kubota L3400 and Deere 790 compare?
   / How would a Kubota L3400 and Deere 790 compare? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a JD 790 with a JD 421 loader and JD #7 backhoe and love it dearly. It is a fine machine. And yet I wonder.
I saw an L3400 hydro yesterday and it was sweet. I have an L4300 gear tractor with ag tires for row crop things so I am familiar with the line but I wonder what the L3400 is llike and how it would compare to the JD 790.
Anyone have any info or comparison on this?
   / How would a Kubota L3400 and Deere 790 compare? #2
MANUFACTURER
MODEL John Deere
790 Kubota
L3400
Engine
Manufacturer Yanmar 3TNV82A Kubota E-TVCS
Engine HP (kW) - gross 27.0 (17.9) 34.7 (25.9)
PTO HP (kW) - Gear transmission 24 (17.6) 29.0 (21.6)
PTO HP (kW) - Hydrostatic transmission --- 27.5 (20.5)
Rated engine speed, rpm 2700 2700
Type Diesel Diesel
Operating range 925-2890 ---
Aspiration Natural Natural
Cylinders/Displacement, cu. in. (liters) 3 / 81.2 cu. in. (1.3L) 3 / 101 (1.647)
Cylinder Liners Cast-in-block Cast in Block
Bore and Stroke, mm (in.) 82x84 (3.23x3.31) 87x92.4 (3.4x3.6)
Compression Ratio 18.1:1 ---
Lubrication Pressurized ---
Cooling System Water pump ---
Air Cleaner Single-stage dry (manual steering) or two-stage dry (power steering) Single Element
Engine Shutoff Key switch Key switch
Engine Torque @ rated speed, ft./lb. (N/m) 54.1 ft./lb ---
Fuel Tank Cap., US Gal. (L) (Open; Cab) 6.3 (23.85) 9.0 (34)
Electrical
Type 12 volt 12 volt
Battery Size (CCA) 500 490
Alternator (12 volt, amp) 20 ---
Starter Size, hp (kW) 1.9 hp (1.4 kW) ---
Fuel System
Type Direct injection Indirect injection
Injection Pump Type In-line with electric shutoff ---
U.S. gal./hr (L/hr) @ 100% load* --- ---
*Fuel consumption rate should be used for comparison purposes only. --- ---
Transmission
Std. Transmission; Forward/Reverse Sliding gear; 8F/2R Sliding gear and constant mesh; 8F/4R
Opt. Transmission; Forward/Reverse --- Hydrostatic - 3 range
Left-Hand Reverser No ---
On-The-Go Shifting (Yes/No/Partial) No ---
Direction Reverser; Forward/Reverse No ---
Final Drive Spur gear Spur Gear
Brakes Dry shoe Wet Disc
Steering Power steering Power Steering
Clutch; Wet/Dry Dry: Single Stage (2WD) / 2 Stage (4WD) Dry dual stage
Clutch Disk Diameter, in. (mm) wet clutch 8.46 (215) ---
Drawbar Tongue Weight Capacity, lb. (kg) 675 (306) ---
Axle Capacity (in operation) --- ---
Front, lb. (kg) 1343 (609) ---
Rear, lb. (kg) 1922 (872) ---
Creeper No ---
Hydraulics
Type Open Center Open Center
Pump Rated Output, gpm (L/min.) 9.4 (36.4) 10.1 (38.2)
Steering 4.2 (15.9) 3.8 (14.5)
Implement 5.4 (20.5) 6.3 (23.9)
Pump Type Single gear (Manual steering models); Dual gear (Power steering models) ---
Maximum Operating Pressure (PSI) 2050 ---
Draft Control Type Position control Position control
Remote Control Valves Available 2 ---
3-Point Hitch
Type Category I Category 1
Lift Capacity (24-in. behind link arms), lb. (kg) 815 (370) 1435 (651)
Lift Capacity @ lift link ends, lb. (kg) --- 1998 (906)
Power Take-Off (PTO)
Standard Rear @ 540 Rear @ 540
Optional Mid @ 2100 ---
Control Trans. Driven - Single Stage Clutch; Continuous Live - Dual Stage Clutch Live-continuous
Clutch --- ---
Brake (for Mid and Rear PTO) Wet disk ---
Fluid Capacities
Fuel Tank, gal. (l) 6.3 (23.85) 9.0 (34)
Cooling system (includes coolant bottle), qt. (l) 25.3 (24) ---
Crankcase with filter, qt. (l) 4.3 (4.1) ---
Transmission and Hydraulic System, gal. (l) gear 16.3 (15.4) ---
Transmission and Hydraulic System, gal. (l) hydrostatic --- ---
Front Axle Gearcase (MFWD axle), gal. (l) 0.56(2.13) ---
Final Drive
Type Spur Gear Spur Gear
Engage On-the-Go Rear Differential Lock Yes ---
Operator Station
Rollover Protective Structure OSHA, SAE, ASAE ---
Rigid - Foldable - Telescopic Rigid Foldable (option)
Platform - Flat/Straddle Straddle Straddle
Gear Shift Location - Console/Floor Floor/Trans. Housing ---
Cab
Compliance --- ---
Visibility --- ---
Air Conditioning, Temperature Differential --- ---
Doors --- ---
Platform - Flat/Straddle --- ---
dB(A) Rating --- ---
Seat Suspension System --- ---
2WD Dimensions
Wheelbase, in. (mm) 61 (1550) 63.3 (1610)
Front Tread Range, in. (mm) --- 41.3 (1050)
Rear Tread Range, in. (mm) --- 40.2 (1020)-50.8 (1290)
Minimum Rear Tread Setting, in. (mm) --- 40.2 (1020)
Front Axle Clearance, in. (mm) --- 13.6 (345)
Turning Radius w/Brakes, ft. (m) 7 (2.1) 7.9 (2.4)
Turning Radius w/o Brakes, ft. (m) 8.3 (2.5) ---
Unballasted Operating Weight, lb. (kg) --- ---
Approx. Ship Wgt, lb. (kg) Open; Cab 1930 (875) 2403 (1090)
MFWD Dimensions
Front Tread Range, in. (mm) --- 43.1 (1095)
Front Axle Clearance, in. (mm) --- 13.4 (340)
Turning Radius w/Brakes, ft. (m) 7 (2.1) 8.2 (2.5)
Turning Radius w/o Brakes, ft. (m) 8.7 (2.7) ---
Limited Slip Differential --- ---
Approx. Ship Wgt, lb. (kg) Open; Cab 2105 (955) Gear - 2580 (1170), HST - 2600 (1180)
Standard Tires
2WD --- ---
Front 5.00-15 6 PR (F2--Rib) (2 Position) 5.00-15 F2
Rear 11.2-24 4 PR (R1-Bar) (2 Position) 11.2-24 R1
MFWD --- ---
Front 7.00-14 6PR (R1-Bar) (2-Position) 7-16 R1
Rear 11.2-24 4PR (R1-Bar) (2 Position) 11.2-24 R1
Miscellaneous
Underhood Muffler Yes Yes
Joystick SCV Control Yes Optional
Inboard Planetary No ---
Axle Type Flanged ---
Brakes - Type and Control Dry Shoe Wet Disc
Models 1-1 of 1
   / How would a Kubota L3400 and Deere 790 compare? #3
Heck this is an easy one Apples (green) and Oranges (orange) Oranges are better for you!!! :D
   / How would a Kubota L3400 and Deere 790 compare? #4
I think a better comparison would be the L2800 and not the L3400. In my mind the L3400 has it hands down over the 790.
   / How would a Kubota L3400 and Deere 790 compare? #5
The JD 790 a nd L2800 compare quite well. I believe that the L2800 has slightly higher capacities - 3pt and loader. That said all in all, pretty close.
The L3400 has an advantage in HP (along with the 3pt and loader) capacties.
Where the L2800/L3400 have the JD 790 beat (and in my opinion this is why the JD 790 isn't competing with them as well as it could), is the optional simple mechanical hydrostat transmission. Many a tractor buyer that went for the low end / simple no frills machine (me included) took the JD 790 out of the running when we found out it did not have a hydrostat compared to the L2800/L3400 which do.
Personally, if I was JD, instead of cooking up the JD3203 - which at best is going to have marginal sales since it is so close to the 3120/3320 in price, should have gotten Yanmar add a simple mechanical hydrostat to the JD790.
   / How would a Kubota L3400 and Deere 790 compare? #6
I just purchased an L2800 last week after considering the 790. The hydrostat is great. The 790 and L2800 (gear drive) were priced the same and the hydrostat added $1,000.00. I agree that the weight and lift capacities listed were a significant percentage higher for the L2800. I paid $15,900 for the L2800 Hydrostat with LA463 FEL. Both had 0% financing and I think the warranty may be slightly longer on the 790 3 yrs or 2000 hrs compared to 2yrs with an extra yr on the drivetrain on the L2800 or 1500 hrs.
This is early thinking right now but I might look to trade the JD 790 TLB for a Kubota L2800 or L3400 TLB. I really like the JD 790 but the hydro, extra weight and capacities are appealing.
Thanks everyone for the comparison.
   / How would a Kubota L3400 and Deere 790 compare? #8
Gotta tell you, I really don't think the advantage in capacities would be enough to cause me to trade if I were in your shoes ... but thats just me. You sure you don't want to take the opportunity to go up to one of the Grand L models? I think with a LA724 loader a GL3540 with HST would be a worthwhile upgrade.
I have an L4300 already with ag tires for row crop so the need for me is a small tractor -loader-backhoe to do work in the yard and odd jobs around the area.
2025 7ft 10 Drawer 2 Cabinet Workbench (A48081)
2025 7ft 10 Drawer...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A48081)
2013 International...
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
2025 K0520 UNUSED Welded Wire Mesh Roll (A50860)
2025 K0520 UNUSED...
2014 Whisper Watt Generator (A49461)
2014 Whisper Watt...
