How worried should I be - JD 2305 Front Axle
   / How worried should I be - JD 2305 Front Axle #11
Do you have the service or owners manual?
Maybe you can look it up on line,, but,, are you sure the axle calls for gear oil, or did you guess? :eek:
My JD calls for HyTran (whatever it is called by JD,,) transmission oil in the front axle. The tractor is a 4105'
My 4410 owners manual calls for Low Viscosity Hi-Guard in the front differential assembly. I poured in 80W-90 once and then went to read the owners manual. I won't make that mistake again.
My manual calls out for 80W-90 gear oil in the front axle. I think there was even a bold note saying do not use transmission oil. The synthetic Amsoil I put in there states to use in applications calling for 75W- or 80W-90 applications.
As far as metal shavings,, some is normal,
an excessive amount indicates to me that someone operated the tractor in 4WD a lot,, when turning on hard ground. JMHO
I am new at this, so not sure what is considered normal or excessive. Wish I would have taken some photos. I am the 3rd owner, but I know the guy I bought from personally, and I know he barely used the tractor. No idea what the first guy did with it though. There are grass clippings still hanging around underneath, so I assume he used it for mowing.
I have the 200X FEL also, and the tractor was not properly ballasted when I got it, which sounds like it could be hard on the front axle as well. The ballast box had a single cinder block in it. I have since filled the rear tires with PG antifreeze, and added several hundred pounds of scrap metal bolts to the ballast.
   / How worried should I be - JD 2305 Front Axle #14
Well, if that's the reason it should have been on both sides, and 400h is not a lot of use. And tractors don't self destruct even with extensive use of 4WD on hard ground, a lot of those that use a loader always run in 4WD without problems, a least proper axels with planetary reduction gears.
   / How worried should I be - JD 2305 Front Axle #15
I already changed my front axle gear oils, twice before my 450 hrs, but my next service I will switch to the fully synthetic Amsoil gear oil. I don't know why I didn't think of Amsoil the first time, but their line of fully synthetic products is of the highest quality. I went online today, and found they really are much more than just a motor oil supplier.
1992 Ford L900 Cab Chassis with Low Milage Cummins (A55315)
1992 Ford L900 Cab...
2011 Freightliner M2 112 Tri-Axle Dump Truck (A55852)
2011 Freightliner...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
UNUSED PABREAK RT260 - 72" HYD TILLER (A57193)
UNUSED PABREAK...
(2) SPACE-RAY INFRARED HEATERS, INDUSTRIAL (A57192)
(2) SPACE-RAY...
UNUSED FUTURE FT-YLJ100 HYD TRACK PIN PRESS MACHIN (A57193)
UNUSED FUTURE...
