How warm is your shop/garage?
   / How warm is your shop/garage? #21
I have the sprayed on insulation (2-4 inch thick ceiling/sidewalls)in my 34X24 barn (14ft sidewalls).I have a 35,000 BTU unvented propane wall gas heater and at 10 degrees outside I can get it up to 70 degrees inside the barn.coobie.
   / How warm is your shop/garage? #22
Ohh how I covet the, with thine warm shops:laughing:
I have so many things that need fixed on my old shed but I have to do a couple more things to the house b4 I get to start blowing money in my tinker hut(or so the better half says:p)
I just think warm thoughts and have lots of coffee on hand.
   / How warm is your shop/garage? #23
I'm jealous of everyone with warm garages. Mine is detached and 50x30 with 2 floors and about 10' ceilings on the first floor. Its not insulated, but I did put in some electric shop heaters and can get it tolerable in the small area I'm working that way. It tends to lag behind the outside temperature by about a day, so if it's 30 outside and then 50 the next day the garage will still be 30 and vice versa. I eventually want to insulate and heat it, but given the size I'm hesitant because of the cost.
   / How warm is your shop/garage? #24
I keep mine about 35* just to keep the water from freezing when I,m not working out there. When I'm working in the garage, I turn the t.stat up to about 68-70*. I have central a/c & heat in the shop so, I'm cool in the summer & warm in the winter:thumbsup: garage is 30x40 insulated
   / How warm is your shop/garage? #25
I live in MI and installed 2" styrafoam under concrete floor slab and down 2' inside of footer. Walls are insulated R11 fiberglass and ceilling 6" fiberglass. Door has 1" foiled celotex. I have a simple in wall between studs gas heater that uses outside air heated by exhaust out for combustion. Does not take long to heat but once that cement is room temp (after 6 hours) you can open bay doors and change air out with vehicle close up and rebound room air pretty quick. Slab is comfy in worst of weather but I always keep thermostat at 40 to keep from freezing chemicals, paint etc. Parts cleaner is not bad to work in probably the last (30 gallon) to warm up.
   / How warm is your shop/garage? #26
Shop is mostly around 42 when Im not there, 68 when I am. Have it fully insulated and a propane 125,000 btu ceiling unit
   / How warm is your shop/garage? #27
I am thinking of building an ICF garage/shop (R-22) and utilize insulated garage doors.
My question is what is a good ELECTRIC heater that can be mounted at ceiling level so that it can keep the garage at a nice 50F during winter?
   / How warm is your shop/garage? #28
I am thinking of building an ICF garage and utilize insulated garage doors.
Plenty out there, the type and size depends on the size of the garage. I use a Dimplex 4000 Watt heater (240V), I really need one per bay, but have large bays and no insulation, so its likely you could get away with less or just a single larger heater unit.
If it's staying around 45 degrees you did a good job of insulating it. I have a 3 1/2 car attached garage (insulated) and mine is like B P Flick. About 10 degrees above ambient.
Thanks! Forgot to add, it's a detached garage. And, how could I forget a picture....:laughing:
   / How warm is your shop/garage? #30
I too, envy those of you with a heated garage. :thumbsup: I poured a 16x24 foot slab in Nov 2009. Buoght the lumber to frame it las month, hopefully will get it built this summer.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
UNUSED X-STAR SKID STEER QUICK ATTACH LAND LEVELER (A51243)
UNUSED X-STAR SKID...
IRONCRAFT 84" ROTARY MOWER (A51243)
IRONCRAFT 84"...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2022 CATERPILLAR 299D3 SKID STEER (A51242)
2022 CATERPILLAR...
Quick Attach Hydro Slide Pallet Forks (A50514)
Quick Attach Hydro...
