how to
/ how to #3
How do i change hydraulic fluid in my ford 2000
might help if we knew which 2000 you have.. the 3 cyl or the older 4 cyl.
the older 4 cyl has a seperate hyd sump.. the 3 cyl the hyds share the rear end oil.
4 cyl, hyds oil is in the center housing.. fill plug under left front side of seat under thigh area..
drain plug under machine pretty much right under seat area. ALL the way back of the tractor is a diffy plug, and ahead if the hyds plug is the trannybung.. ahead of that is the crankcase bung..etc. so you got 4 drains. one under engine.. one under tranny, one under hyds.. one under rear end.
if the fluid is emulsified and wattery, dump in a couple gallons of diesel and a quart of atf type f or dex merc 3 fluid, and a pint of 90% rubbing alcohol, start up and drive around the yard and then drain again. then refill with utf fluid meeting m2c134 spec. make sure you cut a new gasket from thin cardboard or gasket paper, poste rboard, etc.. for the fill/drain plug... level is checked with a dipstick on the left side by the pto lever
for the 3 cyl, pretty much same CONCEPT, rear most drain.. drains hyds and diffy, if dirty.. flush.. then refill with clean utf. level check plug is on lower right side of center housing
/ how to #5
post back if you hit snags..
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
KMC 3376 (A64126)
KMC 3376 (A64126)
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
