How to weld 1"x2" bar to each other?
   / How to weld 1"x2" bar to each other? #11
I would read up some more and practice some on some scrap to make sure you are getting good penetration. When done, clamp your welded up practice pieces in a sturdy vise and work it over with a big sledge hammer. If your welds hold, you done good and can proceed with your project.
Good welds don't have to be pretty but they must have good penetration. Good Luck.
   / How to weld 1"x2" bar to each other? #12
I would also suggest that you get everything setup as it needs to be to work for your SSQA and attachments. Then mark it all well and take it to a welding shop that works with thick stuff frequently.
I do a decent job if I do say so myself on up to about 3/8” with very good penetration and ok with 1/2” thickness. Once beyond 1/2” thickness, I take stuff to someone who does it regularly. It is my opinion that when the material thickness gets greater the stress factors increase and potential dangers of injury on failure increase greatly.
My $0.02 worth. Probably over priced at that!
   / How to weld 1"x2" bar to each other? #13
Beveled both sides and a welder with sufficient amps for penetration and flow.
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
9000 (A47477)
9000 (A47477)
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2014 Ford Fusion Passenger Car, VIN # 1FA6P0H77E5377755 (A56859)
2014 Ford Fusion...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55315)
Michelin CARGOXBIB...
2016 FREIGHTLINER CASCADIA SLEEPER (A57880)
2016 FREIGHTLINER...
