For those that want to know more but not badly enough to follow a link:
Quoted: I recently purchased a SSQL to pin-on adapter for my telehandler[1]. Unfortunately, I misread the model number and it doesn't fit my unit correctly. Even worse, round-trip shipping would cost even more than it's worth. Fortunately, the only thing wrong is the spacing between the pin-on brackets is too wide. I've successfully cut them off and measured where they should go. However, I've never welded anything this thick before and while it will NOT ever be supporting anything life threatening, I don't want to create a hazard zone either....
The configuration is 1" x 2" flat bar stock running horizontal with the 2" side facing the brackets. The brackets are also 1" wide and mounted perpendicular to the cross bars so that the 1" wide face is against the 2" face. I have a 200A stick welder and a selection of 3/32" and 1/8" rods mostly of the 6013 and 7018 variety plus a few others. I feel better with the 6013 but I think the results of the 7018 are actually better.
Based on some videos I've watched on the subject I think I should grind in a bevel on the brackets and lay down a root pass with 3/32" 6013, clean it up, and then blend in filler passes with 1/8" 7018 until the weld fillet is about 3/16" thick which would be about 3/8" wide.
