How to use a post-hole digger with L3400 DT
   / How to use a post-hole digger with L3400 DT #1
turkish
How is this done on these tractors? Is it easy to remain stationary while drilling, with the clutch pedal halfway out, so that PTO is driven but wheels don't turn? Any pointers?
   / How to use a post-hole digger with L3400 DT #2
Can't you put it in neutral?
Never having used a PHD, I was under the impression you need to walk forward slightly, at some point, while the auger goes down. Otherwise neutral would be fine. Thanks!
   / How to use a post-hole digger with L3400 DT #5
Place the auger on the ground, put the tractor in neutral and let the clutch out fully. As long as the tractor is in neutral it doesnt matter.
Keep foot on brake to keep tractor from moving
You will probably have to jig the tractor forward or reverse a few times while drilling. When you start out with PHD its best to stop the pto and adjust tractor, then restart drilling.
Ive been drilling holes for many years, and i used to simply depress clutch 1/2 way, set gear while in low range, and slowly release clutch WHILE i continued to drill. dont try this till you comfortable with your setup.
With my new HST tractor, moving while drilling is a piece of cake.
   / How to use a post-hole digger with L3400 DT #6
Easy with my L3200 HST, which doesn't help with your stick.
You do have to move forward or back a bit due to the geometry of the PHD changing as it goes down. That or you end up with a crooked hole.
New Holland T5060 Tractor (RIDE AND DRIVE) (A50774)
New Holland T5060...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52748)
2020 Massey...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
