How to thin out pine trees?
   / How to thin out pine trees? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
My father in law has a tract of land 20 miles away from where we all live. he had the timber cleared on a section of it and today, there is a thick stand of pine trees, probably around 10 years old.
We drove by it yesterday and he said they'd be a lot nicer if they were thinned out some to give them room to grow.
I speculate this is maybe a 10 acre tract of land.
Looking at the density of the pine trees, you are not going to easily thin out the interior trees without creating some damage driving in/out.
So, I asked him... what if you simply walked through them and cut the target trees down and let them lay on the ground to rot?
"ohhhhhhhh, that would be bad"
I asked what would be the problem there....would they not simply rot away after several years.
"well, yes, I suppose they would"
and then the subject pretty much went by the wayside.
So, I'll ask here...
If you have a thicket of pine trees and want them thinned, would you want/need to remove the downed trees or would it be ok to leave them in place to rot on their own?
I would think by leaving them in place, you could VASTLY speed up the thinning process and you would not need to do something with them (burn?)
I think they're too small for the paper mills (merely a guess on my part).
Thoughts?
   / How to thin out pine trees? #2
This link gives some guidance on thinning. In our neck of the woods slash is usually piled in a clearing and left to rot. We have very dry summers here so leaving it in place increases fire risk. Some land owners burn their slash piles during the wet season. I haven't done so with mine - it provides a wild life habitat and will eventually rot down quite well after which I'll spread it on the forest floor.
http://www.oregonforests.org/assets/pdfs/LO_Factsheet_Thinning.pdf
   / How to thin out pine trees? #3
My first thought was a mulcher head on a track steer.
   / How to thin out pine trees? #4
A lot will depend on the species of pine, the history of the stand, and where your FIL wants to go with the stand in the future. Likely a southern yellow pine stand?? Planted or self seeded?
I'd strongly suggest getting in touch with a local forester and find out if there is a market to pay for the thinning, or if there is a need at this stage to do anything. Its possible the stand will self thin with some of the dominant trees taking over leaving the lesser trees behind. All depends on what stage the stand is at.
Surely nothing wrong with cutting and leaving them lay, but easier to just hack and squirt to kill the tree and let it die and fall whenever. There may be other things to remove at the same time to improve the stand. Talk with a forester. :)
   / How to thin out pine trees? #5
we've got about 50 acres of pines that maybe 7-9 years old or so. They were planted, but not very neatly (that's another story)
We talked to our forester about thinning them out and he said just to let them keep on growing. Eventually, it will thin itself out naturally (to a point)
   / How to thin out pine trees? #6
I think beentheres advice is right. Sort of depending on long range goals you might have. I sort of favor thinning when they aren't too big so they can drop and not badly damage other trees. Sure they can grow all at once. Survival of the fittest and all of that. With selective clearing now you will get larger trees sooner when they aren't all fighting for sun light and water. The fire hazard is another aspect.
They can lay on the ground and rot back in of course. Skidding them out to a large pile decreases burning material for a forest fire. If they are large enough for firewood sell some of that.
Creating a few bird trees is a good idea so that they can help control insects. Or hang some bat house around the area.
Talk with a Forester or Agriculture specialist and see what they can offer.
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2021 KOMATSU WA200-8 WHEEL LOADER (A60429)
2021 KOMATSU...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
Volvo L306 (A57148)
Volvo L306 (A57148)
