How to test safety switches
   / How to test safety switches #1
jayhawk238
Featherville Idaho
2004 Kubota L5030
What is the easiest way to test the safety switches on my L5030? Having a no start problem and need to see if one of the switches is the cause. We think it might be a safety switch or maybe a starter solenoid. Can still start the tractor but have to by hot wiring the starter which bypasses all the safety switches. Plus I can't use my remote start!! 😂;)🙃
   / How to test safety switches #2
Easiest would probably be to use a jumper wire, or pull the connector and jump it with a paper clip or something. Most of them seem to be fairly easy to get to.
The only one I've ever had any issues with was on the L3800, when the one for the forward/reverse pedal apparently didn't go to the neutral position like it should. So that was more of a mechanical issue than electrical.
   / How to test safety switches #4
You can test individual switches with an ohmmeter if you can find them. As Jayhawk said though the problem could be mechanical. My problem was the rod upon which the seat pivots came loose on one end causing an intermittent problem.
KEWANCE 200 9' GRADER BLADE (A51243)
KEWANCE 200 9'...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2014 Jacobsen AR3 Commercial Mower (A50322)
2014 Jacobsen AR3...
John Deere 603 3 pt Mower (A50514)
John Deere 603 3...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2013 BMW X5 xDrive50i AWD SUV (A50324)
2013 BMW X5...
