How to tell a good new cylinder from a bad one?
   / How to tell a good new cylinder from a bad one? #1
hbaird
Deadwood Falls Louisiana
Jinma JM200LE
I need to buy 6 cylinders for a coming backhoe project. The only, far sure, brand I have found with the size I need is Prince, but the Prince cylinder size I need is not discount retailed in the US. A US supplier has the size I need but I know not about the quality. If I buy one of what I need, what all should I look far to decide on buying the rest? I can modify the design and use a known make instead.
Harold
   / How to tell a good new cylinder from a bad one? #2
If you are building something like one of the CADDiggers, take
a look at Metkit. They were called Metco Supply when I bought
mine. They were all 3" OD welded cyls and $100 each, but that
was 10 y ago. The quality of these no-brand cyls was fine.
I would not be so concerned about a "name" brand, but I like
the welded over the tie rod cyls. I have used both types. The
selection is good at Surplus Center.
I am looking at Metkit and CDP in Canada. I will use Metkit Hydraulics if I build the 608. The CDP uses an 18in compressed, 10in stroke, 2in bore welded cylinder made by Prince and not sold in the US. I have not decided yet which way to go.
Harold
Yes thank you, I have seen them. I also need cross tube ends and 1in pins. The variation in cylinders is very large and the specs for this come back to the Canadian Prince. If lived in Canada I could walk in to a Prince Auto and buy what I need. I think if I build the CDP backhoe I will cut an inch off the boom extention and 2in off the boom and use 17in compressed cyl.'s. I can get them several places.
Harold
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
9202 (A50322)
9202 (A50322)
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
Electric Concrete Mixer (A51573)
Electric Concrete...
