How to tell a good new cylinder from a bad one?
   / How to tell a good new cylinder from a bad one? #1
hbaird
Deadwood Falls Louisiana
Jinma JM200LE
I need to buy 6 cylinders for a coming backhoe project. The only, far sure, brand I have found with the size I need is Prince, but the Prince cylinder size I need is not discount retailed in the US. A US supplier has the size I need but I know not about the quality. If I buy one of what I need, what all should I look far to decide on buying the rest? I can modify the design and use a known make instead.
Harold
   / How to tell a good new cylinder from a bad one? #2
If you are building something like one of the CADDiggers, take
a look at Metkit. They were called Metco Supply when I bought
mine. They were all 3" OD welded cyls and $100 each, but that
was 10 y ago. The quality of these no-brand cyls was fine.
I would not be so concerned about a "name" brand, but I like
the welded over the tie rod cyls. I have used both types. The
selection is good at Surplus Center.
I am looking at Metkit and CDP in Canada. I will use Metkit Hydraulics if I build the 608. The CDP uses an 18in compressed, 10in stroke, 2in bore welded cylinder made by Prince and not sold in the US. I have not decided yet which way to go.
Harold
Yes thank you, I have seen them. I also need cross tube ends and 1in pins. The variation in cylinders is very large and the specs for this come back to the Canadian Prince. If lived in Canada I could walk in to a Prince Auto and buy what I need. I think if I build the CDP backhoe I will cut an inch off the boom extention and 2in off the boom and use 17in compressed cyl.'s. I can get them several places.
Harold
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A52576)
2023 EAST TEXAS...
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
