Ballast How to take off ballast box on BX2380
   / How to take off ballast box on BX2380 #21
Adjust the Top Link until the Top Link cylinder-fitting slides freely back-and-forth on the Top Link pin. Then implement pressure should be zero or near zero on on Lower Link/implement connection on one or both sides. After one side is free, the dynamic changes on uneven ground and you may need to adjust Top Link a second time.
Wait, you don't disconnect the top link while it is already loose?
   / How to take off ballast box on BX2380 #22
An easy and cheap way to take the ballast box off on a concrete or hard surface is to pick up a movers dolly at Harbor Freight for $10 or so. I built a 2X4 frame and screwed it to the dolly. Just drop it on the dolly and unhook. Easy to move out of the way
Hey, that’s a good idea! I think I will make one up for my rear blower. I store it in a barn that has an old wooden floor that is not strong enough for my tractor to drive on to, so I just drop it at the entrance, and wrestle it over to its storage spot. A furniture dolly underneath would make it a whole lot easier. Thanks for the suggestion!
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
John Deere 1025R (A53317)
John Deere 1025R...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
