How to stop rippling when spreading/dragging with back blade
   / How to stop rippling when spreading/dragging with back blade #1
JimnAZ
Seligman, AZ
None
Hello,
I have a Mahindra 3616 and recently purchased a 7' adjustable rear blade. Currently I'm trying to fix a road we use. We have plenty of clay dirt and cinder mix that I consider as road base. While I spread this on the road, I get a lot of ripples/waves/ridges. (Not sure proper word to use.)
What am I doing or not doing that is causing this? The more I go over it the more the tractor follows those bumps and just makes it worse.
Any help or tips are greatly appreciated.
Thanks
Jim
   / How to stop rippling when spreading/dragging with back blade #2
Hello,
Thanks
Jim
Do you mean the blade is bouncing up and down while you grade?If so slow down to prevent this..
   / How to stop rippling when spreading/dragging with back blade #3
Blades are notorious for doing this. The front wheels ride up a ripple which cause the blade to drop, the back wheels ride up the ripple and cause the blade to raise.
The best advice I can offer on blade use is to angle the blade like this /:-: and go slow so that the blade does not bounce. Might also need more weight on it. Land planes work better but cost a lot more than blades.
Do you have a front end loader? If so you can back drag the loader to help smooth it.
   / How to stop rippling when spreading/dragging with back blade #5
Personally I do not like land planes. With practice you will be just fine with the boxblade, plus it is more versatile.
   / How to stop rippling when spreading/dragging with back blade #6
If you can turn your blade around 180 degrees, that should help with smoothing.
   / How to stop rippling when spreading/dragging with back blade #7
I read somewhere on this forum to unhook the top link so that the angle of the tractor does not effect the angle of the blade. I personally have not tried this, but sounds like it might work.
Best of luck
-J
   / How to stop rippling when spreading/dragging with back blade #8
Blades are notorious for doing this. The front wheels ride up a ripple which cause the blade to drop, the back wheels ride up the ripple and cause the blade to raise. The best advice I can offer on blade use is to angle the blade like this /:-: and go slow so that the blade does not bounce. Might also need more weight on it. Land planes work better but cost a lot more than blades. Do you have a front end loader? If so you can back drag the loader to help smooth it.
Angle as shown above then straighten and back blade in reverse. Or pickup a landscape rake with gauge wheels.
   / How to stop rippling when spreading/dragging with back blade #9
Please elaborate as to why you do not like land planes.
   / How to stop rippling when spreading/dragging with back blade #10
Hello,
Thanks
Jim
What make and model rear blade do you have?
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2016 Ford F-150 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2019 CATERPILLAR 226D SKID STEER (A52709)
2019 CATERPILLAR...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2015 Toro Reelmaster 5510D Fairway Commercial Reel Mower (A56857)
2015 Toro...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
