How to stop rippling when spreading/dragging with back blade
   / How to stop rippling when spreading/dragging with back blade #21
I use the "butter knife" method, myself.
Here's another way to get the disconnected top link effect, but with less hassle:
Rather than disconnecting the top link, make yourself a section of chain that you can use in place of the top link. This will give you the benefit of "unpinned" operation when the 3pt is lowered & the chain is slack, but still allow you to lift the 3pt & blade when you want to stop dragging without having to get off the tractor to pin and un-pin the top link. This will save you a lot of time if you have to do a lot of maneuvering or turning around during the job.
   / How to stop rippling when spreading/dragging with back blade #22
Some of this advice depends on what your drive is made of. I have hard packed 411 limestone, which is 3/4" down to dust. It must be moist to allow the cutting action to re-grade. Once I break a lot of the surface, level low spots, and have loose material to work with, I can use the blade backwards to finish. Many driveways consist of 57's (clean 3/4" stone) or something similar. That remains loose and can be back dragged from the start.
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
1996 International Water Truck with a Caterpillar Engine (A56435)
1996 International...
White Metal Roof Panels (A55758)
White Metal Roof...
2019 SPM 2500HP QUINTUPLEX FRAC PUMP (A58214)
2019 SPM 2500HP...
