How to stop rippling when spreading/dragging with back blade
   / How to stop rippling when spreading/dragging with back blade #1
JimnAZ
Bronze Member
Seligman, AZ
None
Hello,
I have a Mahindra 3616 and recently purchased a 7' adjustable rear blade. Currently I'm trying to fix a road we use. We have plenty of clay dirt and cinder mix that I consider as road base. While I spread this on the road, I get a lot of ripples/waves/ridges. (Not sure proper word to use.)
What am I doing or not doing that is causing this? The more I go over it the more the tractor follows those bumps and just makes it worse.
Any help or tips are greatly appreciated.
Jim
   / How to stop rippling when spreading/dragging with back blade #2
Hello,
Jim
Do you mean the blade is bouncing up and down while you grade?If so slow down to prevent this..
   / How to stop rippling when spreading/dragging with back blade #3
Blades are notorious for doing this. The front wheels ride up a ripple which cause the blade to drop, the back wheels ride up the ripple and cause the blade to raise.
The best advice I can offer on blade use is to angle the blade like this /:-: and go slow so that the blade does not bounce. Might also need more weight on it. Land planes work better but cost a lot more than blades.
Do you have a front end loader? If so you can back drag the loader to help smooth it.
   / How to stop rippling when spreading/dragging with back blade #5
Personally I do not like land planes. With practice you will be just fine with the boxblade, plus it is more versatile.
   / How to stop rippling when spreading/dragging with back blade #6
If you can turn your blade around 180 degrees, that should help with smoothing.
   / How to stop rippling when spreading/dragging with back blade #7
I read somewhere on this forum to unhook the top link so that the angle of the tractor does not effect the angle of the blade. I personally have not tried this, but sounds like it might work.
Best of luck
-J
   / How to stop rippling when spreading/dragging with back blade #8
Blades are notorious for doing this. The front wheels ride up a ripple which cause the blade to drop, the back wheels ride up the ripple and cause the blade to raise. The best advice I can offer on blade use is to angle the blade like this /:-: and go slow so that the blade does not bounce. Might also need more weight on it. Land planes work better but cost a lot more than blades. Do you have a front end loader? If so you can back drag the loader to help smooth it.
Angle as shown above then straighten and back blade in reverse. Or pickup a landscape rake with gauge wheels.
   / How to stop rippling when spreading/dragging with back blade #9
Please elaborate as to why you do not like land planes.
   / How to stop rippling when spreading/dragging with back blade #10
Hello,
Jim
What make and model rear blade do you have?
20 ft. Shipping Container (A53117)
20 ft. Shipping...
Landhonor RSB-14-80W, 80" Rock Bucket (A52384)
Landhonor...
2012 Tiger 130BBL Vacuum Trailer (A53117)
2012 Tiger 130BBL...
Diamond (A53117)
Diamond (A53117)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2021 John Deere 1023E Tractor (A52384)
2021 John Deere...
