How to secure tractor while operating PTO generator
   / How to secure tractor while operating PTO generator #31
Is this a serious question?:confused:
keep asking that question as the cops and lawyers are banging on your door because some neighbors lil precious got its self killed.
you have 2 parts to secure. 1 pto shaft and generator. 2 controls on tractor.
3 options, 1 portable electric fence that is 7-8 ft high movable insulated base so you can move it away when neccessary. metal chain and padlock for the door. wear lineman boots/gloves to access.
2 lockable shed like structure. a battery room would be a decent starting point for how you would want to design it. you would need a large section that is chicken wire at the bottom and top of opposet sides. you can easily put hinged pannels so that when not in use the place could be completely sealed.
3 2 part. a mini shed to cover the generator up to the rear axel/wheels with a bottom cover so no crawlers get under. you need to protect the outlets as well as the pto shaft. you dont need some idiot sticking a nail in a 30 or 50 A socket and wondering why it smells like kfc. nor do you need some one pulling the plug to the power of your house.... lock cab or have chans blocks on the controls so use of clutch steering wheel shift levers are disabled
JD ill be happy to call you strange :D the auto switch is nice and all but 1) its yet another engine i have to pay maintance on, but wont see a whole lot of real use. 2) most people don't realize this but 90% of the generators void warranty of electronics. those include generac auto switching units. got a farmer near here who drops about 500$ in light ballests when his generator kicks in because they are digital equpment and cant take dirty power.
I specifically bought my generator head as it is listed as electronics safe.
   / How to secure tractor while operating PTO generator #32
There. You fixed it.
2 things I will never understand....Liquid in tires and a pto generator for a house.??
Call me whatever you want. I will never understand those 2 things.:confused2:
I'm with you on those! :thumbsup:
   / How to secure tractor while operating PTO generator #33
Hey JD, I must be pretty strange, but then again, I'm a cheap, closet survivalist in my spare time.
Liquid in the tires makes sense to me. It adds weight to the rear end, and since air and liquids are both fluids, as long as it's not corrosive or super expensive, shouldn't be a problem.
I'm with a couple of the others on PTO generators. Why maintain more engines than absolutely necessary?
There is a caveat with a PTO generator. Unlike many dedicated household generators, a PTO generator doesn't have load sensing to throttle up the tractor engine when more power is needed. So if you have kids turning everything on at once, the furnace igniter and forced hot water pumps, the dryer, dishwasher, freezer, washer, AC, and the well pump, you're going to get a massive dip which won't do your appliances' motors, or your electronics much good. What I would recommend with a PTO generator (or even a cheaper stand-alone generator without that load sensing) is a smart UPS/power conditioner that can store power in batteries in the unit and deliver a level and smooth cycle of power whenever you get spikes in demand.
   / How to secure tractor while operating PTO generator #34
Tractors have a governor throttle unlike a car or truck. If you set the speed to PTO speed with no load and then place a load assuming you have enough power it should maintain the speed just like a generator.
   / How to secure tractor while operating PTO generator #35
I do take it as a serious question, but unless the kid is deaf there's enough natural instinct to stay away from a tractor running at pto speed. If anything try and bring a kid in close they will be scared, even kids who ride around on Daddy's lap on the lawn tractor would be apprehensive about approaching by themselfs IMO
Swimming pools, ladders, open holes in the ground yes dangerous for kids.
A tractor grunting away in a strangers yard I really doubt it.
Teens looking for a joyride or something to vandalize sure, but they're not gonna want to mess with a spinning pto shaft.
But since there's no guarantees and we are talking about the little kids, safety, liability etc.
I know someone mentioned a fenced in area but how about just a roll of that light weight construction fence, just wrap it around the whole package, tractor and generator, and tie it together, simple, cheap, temporary and should keep all but the most determined away.
JB.
   / How to secure tractor while operating PTO generator #36
Like I previously said.
Shouldn't be a problem with a properly shielded PTO. If you are that uneasy about an unsupervised running tractor then the tractor shouldn't be running unsupervised.
   / How to secure tractor while operating PTO generator #37
There is only one right answer. A tractor is not designed nor intended to be left running unattended. If you need something to do that, buy something designed to do that, like a stationary generator with the appropriate safety features.
   / How to secure tractor while operating PTO generator #38
Really?
You should tell that to the thousands around here that use their tractors for real work.
   / How to secure tractor while operating PTO generator #39
Really?
Oh please. "real work" does not mean leaving your tractor sitting in front of the barn running at PTO speed while you go to lunch or shopping. Let alone in front of your house. Fact is, they are not made to do that UNATTENDED and you know it. Yes, you can use them to run a variety of equipment while stationary off the PTO like augers, conveyors, pumps, and even PTO generators. But, they are, obviously, not made to sit there and do that with nobody around. That would be why they have those "wheels" and a "seat" for an operator to sit on. It's also the reason they are called "tractors" and not "stationaries". It is simply the wrong choice to do work like that in that situation. If you need something to run a pump or generator for hours on end with nobody around, you should consider a proper stationary power plant. Obviously, an emergency it could be used to run a pump or a PTO generator, but I wouldn't consider a power outage to be an emergency that warrants this, particularly when nobody will be home. If you need to leave, shut it down.
The mere fact that he has to ask the question says that it is a poor choice.
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A58018)
2017 VOLVO VNL64T...
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
