How to replace fuel pump
/ How to replace fuel pump #1
winter5470
punta gorda, fl
lk 2552
I have kioti 2552 tractor. Recently it started leaking fuel at the fuel pump. By tightening the screws I was able to slow the drip down some. My guess is I have a bad gasket. Searching online it looks like just replacing the pump for $58 is the way to go. I did not see anybody selling just the gaskets.
My main question is how do I replace the pump without introducing air into the fuel lines. I ran it out of gas once and had to bleed the lines. I do not want to do that again!
Any help or suggestions would be appreciated.
Kurt
/ How to replace fuel pump #2
Replace the pump. Bleed the fuel lines; not a big a deal. Then check the engine oil (smell test and dip stick level) for Diesel contamination; some lift pump failures will allow fuel to get into motor oil. A tiny amount of fuel is not a big deal but enough to raise the oil level on the dip stick warrants an out-of-cycle oil change.
Kubota ZD221 48in. Zero Turn Commercial Mower (A64194)
Kubota ZD221 48in...
(UNUSED) GOODYEAR 28L-26 TIRE (A64278)
(UNUSED) GOODYEAR...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A67147)
2020 FREIGHTLINER...
LAND PRIDE 10' HYD 6 WAY BLADE (A64278)
LAND PRIDE 10' HYD...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
