How to repair carpenter bee damage?
   / How to repair carpenter bee damage? #11
I want to prep my barn for paint, and carpenter bees have caused widespread damage to the wood. There are numerous holes in the siding-- typically the size of a dime, or a nickle.
The eaves have some larger holes/voids that are maybe 1-2 inches across. Typically where the boards under the eave join together.
What are some options to repair this? I previously used LiquidWood/WoodEpox for a wooden threshold repair, but that stuff is stupid expensive and might be overkill for something like this ???
Thanks!
Bondo. Really.
   / How to repair carpenter bee damage? #12
As other's mentioned, drill the holes to a known size and plug with wood the same size and some waterproof glue. Cut flush with an oscillating multi-tool.
   / How to repair carpenter bee damage? #13
Is the wood cedar? Here, I get hired to replace the wood. My clients have already tried filling the holes, and they just come back and make more holes. Once the wood is replaced, I spray it down really thick with Dawn Dishwashing Soap that mixed about 50/50 with water. They hate the feel of the Dawn on the wood and they go somewhere else. This works for wasps too!!!
I like the idea of using liquid nails. I never tried it, but think that it might work.
   / How to repair carpenter bee damage? #14
I plug the bee holes with a cork and then trim it flush with a sharpened putty knife. Paint or stain over it. Fast and works well, and I got a bag of 100 corks for real cheap some time ago. The corks taper from about 3/8" to 1/2" or so, and fit the holes perfectly around here. You can really wedge them in tight and they do not budge afterwards.
I learned this trick from exterminators, who use corks to cover the holes after dusting them with Drione insecticide. The cork protects the Drione so it lasts 6+ months, enough time to kill any bee larvae that were already inside galleries in the holes and will eventually mature and try to crawl out.
I modify the procedure a bit -- when I see an active hole, I dust it. If there was an adult bee inside, they will stagger out. I've seen as many as 4-5 stagger out of a hole! Then I dust again and leave the hole open for a couple more days to get any other adults that might visit the hole. Then I cork it, trim it, and paint/stain over the top. Never had a bee try to come back to a corked hole or tunnel out from a corked hole.
   / How to repair carpenter bee damage? #16
I guess this is mildly off topic, but a) I had never heard of carpenter bees, apparently they do not live in the Dakotas b) this seems to be a good argument for vinyl or metal siding. I was thinking about wood, but I have no desire to spend part of my retirement filling bee holes. A!so, I don't want to use insecticides outdoors if it can be avoided.
A little more on topic, once patched, would a coat or two of paint stop them? May want to check with a college like TAMU. They seem to be good at insect abatement.
   / How to repair carpenter bee damage? #17
No carpenter bees in these parts. However - there is a bee/wasp that makes a small hole. About 1/8" in diameter. Very infrequently. I use fine sawdust & Gorilla glue to patch these holes.
   / How to repair carpenter bee damage? #18
What are the general thoughts on this (the following)
We get them little SOB's.... unrelated, I'm debating on replacing the guttering. The fascia behind the guttering seems to be their favorite chomping ground.
(never mind the 9 traps I had that were filled with dozens and dozens and dozens of them)
Anyway, what are the thoughts on replacing the natural wood fascia with one of those composite boards?
For the bees, I'm thinking they're not going to touch/bite it.... but I'm unsure how it would hold up with the gutter attached to it?
   / How to repair carpenter bee damage? #19
I use Permachink to seal up holes after they have been purged of critters and filled with WD40.
You can't "repair" the wood carpenter bees have drilled holes into, only seal them up to prevent them from nesting and drilling some more.
If they've gone unchecked for too long your wood loses structural integrity. They are very destructive and will cause you structural problems if ignored too long.
   / How to repair carpenter bee damage? #20
for small voids, etc, i've had good luck with Bondo. believe they make a carpenter version, & sands out nicely
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
35176 (A55758)
35176 (A55758)
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2007 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2007 Chevrolet...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
