How to repair a concrete apron?
   / How to repair a concrete apron? #31
Explore our concrete calculations using:
Concrete Slab Calculator - concrete calculator
Whether it's granite or the local rock available, a similar short ramp, around 22" deep at its peak, has proven durable for nearly two decades with layered compaction. Check out the calculator for your concrete needs!
   / How to repair a concrete apron? #32
As you say things are still moving, rip the concrete ramp out and start again. DIG OUT to SUBSOIL. I think you will find the original ramp is on topsoil( think toothpaste foundation).
Weather you go timber or concrete I reccomend a 3" AIR GAP between the ramp and the building with a steel plate over the air gap.
Also make the ramp longer for greater ease of entry.
Good luck.
   / How to repair a concrete apron? #33
If there’s a steel mill nearby see if you can get slag its heavier than gravel and won move as easily due to rain.
it also packs tight.
Truck Absorptions Attenuator (A54865)
Truck Absorptions...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2011 Ford Ranger (A53314)
2011 Ford Ranger...
Margaritaville Metal Trucks (A53316)
Margaritaville...
Chemical Storage Container (A53316)
Chemical Storage...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
