How to remove drive shaft
/ How to remove drive shaft #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
I do not want to break the plastic safety shroud by prying against it but Id guess that small pin has to be moved/removed to remove this shaft? I tried gently moving it but no luck as of yet.
Thanks
/ How to remove drive shaft #2
Yes the small pin with the spring on it you push it maybe spray it with some rust buster oil......Spray the shaft also so it will slide off....
/ How to remove drive shaft #3
The pin just needs to be pushed in by pressing on the spring side. It might put out a fight so you may want to soak it in penetrating oil for a while.
You could also loosen those bolts that hold the plastic cover so it can flop around and maybe give you a bit more space to press the pin.
/ How to remove drive shaft #5
Maybe a discrete small hole in plastic shield to allow a pin punch to tap on end of spring pin to "free" it after a good soak with penetration fluid if it does not free up enough to press with finger....
Dale
Im sure that can be arranged. Thanks
Got it with little effort. Thanks again
(INOP) 2013 JOHN DEERE TS GATOR (A64280)
(INOP) 2013 JOHN...
2021 Takeuchi TL6R High Flow Compact Track Loader Skid Steer (A61572)
2021 Takeuchi TL6R...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
1997 JLG N40 Electric 40ft Articulating Boom Lift (A61572)
1997 JLG N40...
300 GALLON FUEL TANK W/MANUAL PUMP (A64281)
300 GALLON FUEL...
2025 Tree Boom Mini Skid Steer Attachment (A61572)
2025 Tree Boom...
